Question about General Electric A735 Digital Camera
Battery seem to go almost dead , but will still work.
With new batteries installed, taking six out door pics, the screen says the batteries are either exausted or almost gone.
Check the camera's firmware. There are instructions for updating the firmware on GE's website. Some of the earlier models had issues where the camera would report that new batteries were at a 1/3 charge. Using NIMH or Lithium batteries should also help.
Posted on Sep 15, 2009
    President:
  • 2,761 Answers
The problem may be due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Posted on Sep 11, 2009
Can someone help me on my nikon D3100 freeze problem?
New battery that is fully charged. My Nikon D3100 has had the problem of freezing every ten or so pics since it was a couple of months old. Still does it today after six months of use. I take a few hundred pics with it when shooting but only shoot once or maybe twice a month.
Have to take the battery out, put it back in etc. each time. Sometimes it allows me to power off and then back on but either way it's a pain in the rear and a serious "time waster".
Feb 12, 2012 | Nikon D3000 D3100 18-55mm
Install new charged rechargable batteries and will be dead batteries in bout 2 hrs not even turned on. take 2 pics and gone
Is your newly charged battery are new? Maybe your battery is worn out already. Or buy a new rechargable batteries and observe. Remember do not over charge your battery, this is always the reason why your battery got easily worn out. Thanks
Sep 11, 2011 | Kodak EasyShare C875 Digital Camera
What is the smog equipment part between the carburetor and intake manifold on a 1982 Ford Fairmont Futura straight six engine called?
I believe your talkng about an exhaust gas recirculation (EGR) plate. This is a ported plate that allow exaust gasses to be recirculated back into the intake stream. Attached to it is the EGR valve itself. Here is a pic diagram showing the assembly. The plate is listed here as a carburator spacer.
May 09, 2011 | Ford Fairmont Cars & Trucks
My fuji finepix s5600 has stopped taking pics,just as i put new batteries into it,i can look at previous photos that i took,but it just wont take the pics,why?
Is it showing any message on screen as to why it won't take pictures or is it when you switch over from viewing to taking pics that it shuts off or just won't let you take pics?
Jan 07, 2010 | Cameras
Cant take a pic says card is full
If this is a brand new memory card, the two things to do/check are:
- Make sure the camera supports 2GB of memory (manual should say that)
- Format the memory card - the manual should give detailed instructions of how to navigate through the menu and perform a format on the memory card
Dec 26, 2009 | Olympus Stylus 850SW Digital Camera
When taking pics will not show pics in lcd screen
If no power on the camera at all:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If there is power on the camera, but the LCD is black KODAK recommends a repair. If the camera is OoW.
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
Dec 05, 2009 | Kodak ZD710 Digital Camera
The LCD screen does not display when the camera is turned on. I have installed new batteries. The screen works to see pics in the memory but does not work when taking a new pic. Also when using the view...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Nov 16, 2009 | Canon PowerShot A60 Digital Camera
How to install exhaust in a 2004 sentra se-r spec v
Well there are several different ways you can install an after market exaust. The two most commom ways are weld in and clamp in. To stay legal most usually you will go with a cat back exaust. It gets its name due to the fact you leave the factory catalitic convertor in place and the rest is all new.
The easiest way to install a cat back exaust is to purchase the model exaust designed to go in you Nissan. These usually use the same bends as the factory. They also use all the same hangers.
1. Using a reciprocating saw, cut the exaust loose about 4 inches behind the converter.
2. remove all hardware from the factory exaust. Anything that will not be used in the reinstall.
3 Snake the exaust over and out from above the rear axle.( If it has one)
4.If any new hangers need to be bolted in, go ahead and take the time to install them now while everything is out of the way.
5. Now you are ready to install the new exaust system. This is ususally reverse of the disassembly given it is a one piece exaust. If it is a multiple piece exaust system it may need to be welded together first or once installed. If it is a clamp style assembly, install the exaust with all clamps in plce, but not tight.
6. once all the components are installed, check everything for alignment. Once you are happy with the fit, you can go ahead and weld/clamp everything in place.
Sep 12, 2009 | 2004 Nissan Sentra
It says battery exausted even with new batteries
I beleive your batteries are of incorrect type or you need to set the type of the battery through menu. My favorite batteries are from Wal-mart: Energizer rechargeable Ni-Mh 2450mAh, (15 min recharging time) they fit any type of camera without setting the battery type through menu. Some incorrect type of batteries often damage the CCD. Ni-Mh Energizer never damages the CCD (black screen), while regular (non-rechargeable) Energizers may damage CCD in Sony S700 or similar cameras.
Jul 20, 2009 | Nikon COOLPIX L18 Digital Camera
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
General Electric A735 Digital Camera Logo
178 people viewed this question
Top General Cameras Experts
pontelemon
pontelemon
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
