Question about Video Game Consoles & Games
My xbox360 just shut down first nothing would plug into it. Then the next day it wouldn't turn on
    Problem Solver:
  • 5 Answers
If you are seeing a red light, call the Microsoft. Xbox's have a consistency to blow power supply's and red light.
Posted on Sep 10, 2009
Pontiac g6 drive the car a bit went somewhere got out came back 2 hours later all it did was turn over an wouldn't start has plenty gas left it alone for a bit try to start it it fired right up. So I...
flassed less engine power wth????????? Flashed reduced engine power ! Electronic throttle control problem ! Your best bet ,take it to a GM dealer , buick , cadillac , GMC . You do not have diagnostic test equipment or knowledge to even diagnose this.
Jul 06, 2017 | Cars & Trucks
Chevy pickup wont start
have the battery load tested for cell failure. IT will have enough current for lights etc but not enough for the starter solenoid
Apr 28, 2013 | 94-1998 Chevy Silverado / Tahoe Grille...
Epc light in a 2003 Turbo-S Volkswagen beetle turned on, shut off. Next day car wouldn't turn over. How do I fix this from happening and start the car?
check battery volts should be 12.6 volts.if not battery dead.have battery charged and test if battery can be charged alternator faulty.if battery dead cant be charged replace battery.and clean battery cables if EPC warning light still flash have vechicle code scan for faulty accelerator control system or mass air flow sensor.to get vechicle started after replacing battery just turn ignition switch to the on position for 30 seconds then turn off ignition switch then start engine.
Apr 04, 2013 | Cars & Trucks
Turned off after playing, came back the next day and nothing happened. Wouldn't turn on, no lights etc. tried pulling plugs and reconnecting and still nothing. Tried the reset button, still nothing....
Hello
Possible the outlet its plugged into is bad or a blown breaker.Try plugging in something else like a lamp to make sure.
Another problem could be the power supply to the wii is no good.
Oct 09, 2011 | Nintendo Wii Console
Truck broke down no fire.. replaced coil, ing mod,cap rotor.. got fire truck runs... truck down again no fire
I recently had a similar problem. I drive a 94 ram 1500 with the 3.9 6 cylinder. When I replaced the coil it started right up but then cut out and wouldn't start. So I wiggled the wire that plugs into the coil and tried to start it and it fired up again and the next day it wouldn't start. My problem was were the wires connected to the plug came loss. I went to the junk yard found any ram truck from 94 to 01 with either gas engine 3.9-5.2-5.9 and cut the plug off with decent amount of wire and installed it on mine and problem was solved. I also had a catalytic converter problem about 3 months after that was similar but it would start right up and run in neutral fine but when it gear it would bog down and eventually stall. Good luck.
Jul 26, 2011 | 1992 Dodge Dakota
Sudden phone shut down.
better u change your battery and try....
Aug 28, 2008 | HTC P3300 Smartphone
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
