Question about Panasonic Televison & Video
I have a panasonic tv. it has been working dood. however yesterday it gave a sort of ,,, thump and after that the audio went , also the High voltage to the CRT is not there.
Throw the tv away
Posted on Sep 27, 2009
Panasonic pt53wx53 led blinks once
unplug the set---where smoke something has burned.
I would with back off have a look---look at high voltage transformer and that area of board and pay special attention to C509 (brown cap in front of high voltage transformer about 2 inches---it will be marked with that C509 on board.
If it is cracked or burnt it is bad---these fail a lot.
If the set needs to be worked on it has a lightbox---about 8 bolts removed and entire guts or chassis comes out in one piece--can be powered up out of the cabinet.
Let me know if need more information.
May 29, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic dimension 4 microwave/convection oven Micvrowave part of oven not working, convection oven/grill fine. Is it a problem with the magnetron? Is there some form of internal fuse?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | Panasonic NN-C980 Convection/Microwave...
My microwave Panasonic NN-K544WF is not heating the food otherwise it is working
Assuming this is not an Invertor type.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 16, 2010 | Panasonic Microwave Ovens
Sony trinitron kv35s26 (August 1997) no video, only audio
this is the best out there , but you will have to use one with the same chassi #
http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
glad to help! plz give time for a good rating, thanks , j (electech)
what another models fault is in the video, should help find you find problem
Sony
Model:kv32s45
Chassis:AA2d
No video, Has High voltage. Turning up G2 show a very dim full raster and on the sides a very bluish faint bar .
Replace Vert. IC561 (TDA8172)
Comments:
need any more help just ask , thanks
electech
Oct 29, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Visual and power problem
Bad high voltage transformer. Most original transformers are not made anymore by RCA.
Mar 04, 2008 | RCA P52926 52" Rear Projection Television
No picture or audio on panasonic 46" tv
What parts were replaced? Can you hear the high pitched whine when the tubes come on. If not, whoever did the work may have knocked one of the high voltage coils off.
Oct 20, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
No video/audio when TV is turned on..
This set is popular for the main voltage regulator to be bad. If you have a meter check the input voltage . it should be between 135 to 159 vdc. Now pin 4 should be aroud 125 to 130 when you switch the set on. Hope this helps Good Luck
Jun 02, 2006 | Panasonic CT-27SL14 27" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
