Question about Refrigerators
Can you replace ice maker in RS2555Sl> where do you pick up replacement
  • 11,896 Answers
Yes you certainly can. I prefer repairclinic.com they will have every and anything you need for appliances. appliancepros are ok too
Posted on Sep 10, 2009
Whirlpool ED5FHAXVYO3 icemaker not dispensing ice.
Question is there ice still remaining inside the ice maker slots? If not then pour tap water inside the slots to the top and wait until they freeze. If the ice maker drops the ice into the ice bin and does not refill with water you will need to replace the=> W10408179 Water Inlet Valve If the ice maker does nothing while on the=> W10272869 Ice Maker needs to be replaced Appliance 911 Sea Breeze
Aug 12, 2015 | Whirlpool Refrigerators
Troubleshooting a GE TPX24 icemaker
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
My samsung RS2555SL refrigerator ice maker needs to be replaced. I have found the ice maker at the samsung parts store for $61.29. Is it possible to easily replace or should I get a professional? I live in...
this is a easy job . the ice mker will change out with no changes . maytag uses this same unit and is very common . 3 mounting screws and the wire harnes is a plug in / no spec wiring needed .. mm hope this helps . feed back pls .
Sep 19, 2011 | Refrigerators
Not making ice,checked optics ,good ,water valve coil tested good, no restrictionsbut i get no water in tray,also freezer temp is 8 degrees.
OK you mentioned the ice maker had no cubes or not making cubes, try filling tray with water from tap. Let freeze and if the ice drops into ice bin the ice maker is OK. Most times the ice maker thermostat is at fault (pt. 27 in photo) if not cycling. Read OHM's between both coils and they should be very near to same reading, if not replace water control valve=> 4389177 by applying first 120VAC to see if valve opens. If water goes into ice maker this way or OHMs between the two are nearly the same your Ice Maker=>2198597 Ice Maker Assembly may need replaced. If you would like to rebuild your Ice Maker here are the part Breakdown view=>
GS5SHAXN Ice Maker Replacement Parts
Let me know how your ice or water turns out, Thanks Sea Breeze
Feb 11, 2011 | Whirlpool GS5SHAXN Side by Side...
Our kitchen and pantry were flooded because the icemaker wouldn't shut off. My husband had to unplug the refrigerator to stop the water from pouring out
That is a rare happening but the solution is inside the ice maker itself. Click Here=>MSD2732GR Ice Maker Parts Break Down Part 13 is the Click Here=> 627985 Ice Maker Thermostat and sometimes it is just less expensive to replace the complete Ice Maker=> Ice Maker
Assembly
Simply unplug the ice maker from inside the freezer section rear wall until you can replace the part or ice maker. If you have more questions feel free to ask here or my through my web sites. Thanks, Sea Breezesea_breeze_15.jpg
Appliance 911
Dec 08, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Not making ice
There are several possibilities for this and the dual water control valve is one of the possible problems. Try pouring tap water into ice maker tray if no cubes are present. Allow it to freeze and if the cubes drop then the water control valve part Click Here=> 2188542-1 Then you have a possibility that the ice maker thermostat is at fault item number 27 in photo here=> 627985 Ice Maker Thermostat Sometimes the problem is located inside ice maker and buying new makes it more worth the cost than the cost of replacement parts. This is the Replacement and parts here=> 4317943 Complete Ice Maker
If you need additional help I can be found here or here=> Appliance 911, Thanks Sea Breeze
Oct 09, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Samsung rs2555sl ice maker trouble
check to make sure that the tube that fills the ice maker is not froozen upo and causoing this problem
Feb 21, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsang rs2555sl Ice maker
Call Samsung and get a straight answer.
Dec 21, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
