Xterasys XN-2423G (XN2423G) Wireless Adapter Logo
Posted on Sep 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DO NOT HAVE THE CD TO RUN SO DOWNLOAD DRIVERS BUT THERE IS UTILITY AND SET UP BUT NO DRIVERS LOADED
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
482
Points
Pasame el driver de xterasys wireless lan cardbus ps card
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Sep 10, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557370
Points
31058
See: http://www.fixya.com/support/xterasys
You're not the first person to have this problem.
Can't reset windows 7 logon password as error
try this :
  1. Download the Reset Windows Password utility onto an alternative computer. Unzip the download file, you'll get the ResetWindowsPwd.iso file. Burn the ISO file to CD using an CD burning software such as ISO2Disc orBurnCDCC.
  2. Set your Windows 7 laptop to boot from the Live CD. To boot from the CD-ROM drive, you may need to press a key such as F8 or F12 while your computer is starting up and set CD/DVD as the first boot device in BIOS.
  3. After the CD boots, you will have a mini operating system loaded into memory which will launch Reset Windows Password utility. It will not install anything to your hard drive.
  4. Click on the Reset Windows Local Admin/User Password option, the program will automatically detect the Windows SAM registry hive and local user accounts existing in your local computer.
  5. Choose the administrator account and click on Reset Password button, it will remove your forgotten Windows 7 administrator password in a short time.
2helpful
I need set up i lost my cd
Here's the driver and utility, zipped in one file. After download you'll need to unzip it and then run the installation of the drivers.
http://www.zonetusa.com/file/product/d/ZEW2508.zip
If this was helpful and informative please vote with a Thumb Up. Thank you.
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Im trying to download software for kodak 5100 but it keeps saying error 0x80131700...says system DLL's couldnt be loaded?
Is that the full error? if so I'd suggest you stop your background applications using MSCONFIG and then run the Kodak Clear Utility - www.kodak.com/go/clear.
Once done then install the software from www.kodak.com/go/drivers
2helpful
I've totally lost my set up CD for my Canon Scanner.
http://software.canon-europe.com/products/0010565.asp
Presuming Vista OS Canoscan toolbox is the utility. Found in Canon support I might add.
1helpful
2answers
NO BOOT SECTOR ON HARD DRIVE
Afraid you are going to have to get ahold of a copy of the Dell operating system. Once you get that loaded, you can go to www.dell.com to download/install all of the device drivers.
You can actually use any retail operating system version, does not have to be dell. It is only that the dell copy is less expensive. You might try getting that on Craigs List or Ebay.
Good Luck
Do I need drivers for my Modem
install the chipset driver from the dell drivers and utility cd if you cant find it there go to support.dell.com and enter the service tag number and go to the drivers download page and download the drivers..it should fix..hope this helps.
Regards,
Khushroo
Reinstalling sound card drivers
u have came cd with a laptop drvier & utility cd put in cd rom drive it will autorun there was option on sound click on it setup will run
if dont have cd then u can download & install from the by clicking on acer aspire 1640z
I added printer software, and my system is locked up/
why:
it could be a software conflict / component incompatibility between your printer utility and your vista.
here's what you can do:
set your computer to safe mode, then uninstall the printer and its utility from your vista.
once done, reinstall the printer and let vista use its "built-in" drivers (since almost all printers manufactured before 2008 has drivers on vista by default) or let your computer download a compatible driver online.
Top Xterasys Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Xterasys Computer and Internet Expert? Answer questions, earn points and help others
