Question about Vizio VO47L 47 in. LCD TV
Green Fuzz I just purchased this TV less then a week ago and it worked perfect for the first couple of days and then yesterday when I turned it on the screen was green and when tuning into cable and X-box there was a green fuzz that appeared all throughout the screen. what might be the problem?
  • 11,896 Answers
It may be a bad system circuit board. Is it fixable? Yes, but at an expense, all depending on exactly what is wrong. I predict the problem to be the horizontal deflection amplifier and the high voltage generator (called the flyback transformer). The cost of repair is likely to exceed $150.
Is it worth fixing? Probably not because the set is nearing the end of its normal life span anyway. Also, the cost of repair is about the same as a new set of equal value. Now might be an opportunity to step up to one of those new fangled sets with wide screen and HD compatibility - although they are still quite expensive!
Did the electrical work being done cause this? It could have, but I doubt it. When ever I go away or know that I am not going to be using a tv for a while, I always unplug it. Little do most people know that even though the set is OFF, it is still ON a little bit. The remote receiver must always be on so that it can receive the signal from the remote commander when you want to watch tv. Therefore, it is always possible for some backward trending pulse to get into the set. For example, an electrical storm can destroy a tv set if it is plugged in - even though it is OFF. But if it is unplugged, it will not be harmed.
If this is the tv with the ssb pannel it probibly is bad,. if it is that board is not repairable, and can cost about $300.00 ish .
Posted on Sep 10, 2009
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Sanyo DP46840 purchased less than 1 week ago from Walmart. Worked fine for first couple of days, now HDMI connections don't work. monster cable works on other lcd tv and all video sources. rest TV...
Hi gregschirk,
I bought the same model and I am experiencing a similar problem. My HDMI components worked fine before. Now both my cable box and DVD player will not be recognized as HDMI systems. It thinks they are DVI to HDMI connections. Good picture but no sound. Would like to know if there is a fix for this.
Thanks Gilbo72
Nov 27, 2010 | Sanyo Televison & Video
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Nov 22, 2008 | Mitsubishi WS-65819 TV
Screen problems
Sounds like you have caps going bad in video circuit. This will need repair from export. If tv is in warranty, then send back.
Aug 16, 2007 | Hitachi 28LD5200 28 in. HDTV-Ready LCD...
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Jan 30, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Vizio VO47L 47 in. LCD TV Logo
325 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
