Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
4 wheel dive problems.
Hello my name is chris and i have a jeep wrangler YJ and i have a massive problem. i was doing hill climbing and i hade the 4 wheel drive on and the dif lock but then when i went to try the hill again the 4 wheel drive wouldent activate do you think you can help me with my problem...it would be awsum...chris
  • 6 more comments
  • waldo c Dec 11, 2007
    I have a 1991 Jeep wrangler.The 4 wheel drive worked a month ago and now it doesn't. When I engage 4 wheel drive with the transfer case, it engages the front drive shaft, but the front wheels don't engage. there is a vacuum actuator on the front axle that apparently controls the 4 wheel drive. there are 2 vacuum hoses attatched to it and an electrical plug with 2 wires. I traced the vacuum hoses back and found that one attatches to the intake manifold and the other one isn't attatched to anything. I dont think this is right, but I can't find where the other hose is supposed to attatch. This is My first 4 wheel drive so I'm in the dark .can you tell me where the other vacuum hose is supposed to attatch, what do I call the vacuum actuator, and how do I trouble shoot it if attatching the other vaccuum hose doesn't solve the problem?
  • bizflip2008 Mar 09, 2008
    i have a 95 jeep wrangler yj my 4 wheel wont work. my vacum lines seem to be in good shape .what might be causing this problem?
  • jmcfarland30 Nov 15, 2008
    When I put in 4 wheel drive the front tires dont turn! The 4wd light doesn't even come on.
  • Anonymous Dec 02, 2008
    did you figure out the problem cause i have the same prob
  • burtonboards Dec 08, 2008
    when i go to engage 4h and 4l in my 93 wrangler nothing engages the light doesnt even turn on but when i put it into 4l i can hear the humming of being in 4l but i no the 4wd isnt working any suggestions
  • MtnManDoc Dec 26, 2008
    My 1988 Wrangler has the same problem...the Front Wheels do not turn when 4-wheel drive is engaged...
    I am thinking, 1st the vacuum lines, and 2nd the front axle shift motor might need replacing due to the mileage... does anyone know how these vacuum lines go ?
  • batman2324 Jan 20, 2009
    my tranny engages but the indicator light doesn't work and front wheels aren't spinning. i traced the vacuum hoses and one dead ends up against the fire wall does any one know if this is a vent or is it supposed to hook up somewhere else?
  • brialisamb Jan 24, 2009
    my name is brian i have a 90 yj when i shift into 4wd the 4h dose not go in but if i go to 4lo it works ? anyone got any thoughts on this problem?
For the older wranglers using the vacuum system to engage and disengage 4wd, check this out. You should have red, yellow, green, and blue vacuum hoses coming from the transfer case. The red line ends in a check valve so when you do maintenance you can make sure you have vacuum. The yellow line runs to the middle port on the Command-Trac motor. It T's off and runs to a check valve that T's into a black vacuum line. The green line runs to the port on the outside of the Command-Trac motor. The blue line runs to an air vent filter. The black line runs from the inner most port on the Command-Trac motor to the 4wd indicator light and switch. Along the way it's T'd into by the yellow line I was talking about earlier. Hope that helps
Posted on Nov 06, 2009
Hi, I have 97 jeep TJ sahara and my 4 wheel engages sometimes but when I want to get off the 4 wheel drive to 2 wheel drive. It stays in 4 wheel drive for about a minutes while driving and suddenly the jeep gets a jolt and bang sound, that is coming from 4 wheel slipping off to 2 wheel. One mechanic shop told me that it is the universal joint or U-Joint being out of placement.
Posted on Aug 29, 2008
Diagram for 87 yj vacuum lines for 4 wheel
vacuum lines are no hard to find
usually they com out of the intake manifold and go to the actuators
follow the small hoses
Nov 06, 2017 | Jeep Cars & Trucks
1990 Wrangler: I have a 1990 yj with the 4.2, my question for eve...
Most 90 wranglers from 89 to 95 have an ax15 5 speed transmission in them. The 4 cylinders had an ax5 transmission.
May 17, 2010 | 1990 Jeep Wrangler
95 wrangler yj. has no power at high speeds
Have you had fuel pressure tested, and/or filter changed. Have you checked for plugged exhaust, such as catalytic converter? Quite often engine will also run a little hotter than normal when exhaust is plugged.
Nov 05, 2009 | 1995 Jeep Wrangler
1990 jeep yj 4 wheel drive issues
what are you trying to say is that the front wheels wont engage?? if this is your problem? check the actuater on the passenger side axle there are 3 lines that go to it and that is what pulls it in and pushes it out of gear by air.
Oct 06, 2009 | 1990 Jeep Wrangler
4 wheel drive doesnt work.
Has this Jeep been modified at all?
It sounds like the shifter cable was reinstalled backwards.
Specifically the 4-Low "Not Climbing Well". 4-Low should give you the best torque and hill climbing ability.
Do you feel any "Binding" in the steering wheel (difficult to turn)?
Remember a Jeep uses real driveshafts and differentials to give you 4WD - you cannot engage 4WD or 4-Low on dry hard surfaces. It needs a little bit of slip between the wheels for turns.
Check you're fluids too.
Jul 11, 2009 | 1992 Jeep Wrangler
Looking for Service Repair Manual Jeep Wrangler YJ
i have a 1988 jeep wrangler 6cyl with 5 speed transmission. I was shifting the jeep and it got stuck in third gear. We opened it up and saw that the linkage is aligned and everything is in place. I dont know what is wrong and what to do next. please help ....
Jul 10, 2009 | 1992 Jeep Wrangler
1987 Jeep YJ [Wrangler] so owner ship says''
Our Jeep Wrangler YJ's are equipped with a vacuum module on the front axle. It is used to engage the front axle when the transfercase is shifted into 4WD. Check the vacuum lines on the front axle to make sure they are connected. The passenger side axle shaft has a disconnect sleeve that is moved left and right by the vacuum.
Mar 01, 2009 | 1987 Jeep Wrangler
4 wheel drive problem on Jeep YJ
you can also check the 4 wheel drive vacuum switch on top of the transfer case...got mine for 10 bucks from parts store...fixed the problem
Dec 21, 2008 | 1992 Jeep Wrangler
4wd problem jeep wrangler yj 1995
i just bought a used 97 CHEROKEE but i had the same problem, when i got to looking at it i found out the front driveshaft was shot, look at that, if its not it i would say its probably the transfer case especially with an older vehicle like that which is a very expenxive repair
Dec 21, 2008 | 1995 Jeep Wrangler
Jeep YJ 1991 4 wheel drive
if u got automatic front hubs stop put in park pull 4x4 shifter into 4 wheel
manual hubs at front wheels turn the hub locks to the lock position and then pull the 4 wheel shifter inti 4 wheel
also look over drivers sun visor if the tag aint worn off the direction are there... have fun 4 wheeling and keep the rubber side down
rank, rate & vote for my solution
Dec 20, 2008 | 1991 Jeep Wrangler
Car Audio & Video Logo
714 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
