Question about Jenn-Air JMV8208AAS Microwave Oven
Oven works but it no longer is self-cleaning. No
Oven works but it no longer is self-cleaning. No heat. Fan works. Model S156w
  • 71 Answers
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Posted on Sep 16, 2009
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
How do I fix the oven when it no longer heats food but all other features of the oven work fine?
Could be a burnt out fuse but most likely its the heating coil is burnt out.
Sep 01, 2015 | GE Microwave Ovens
My plate just cracked while microwaving popcorn
Make sure you don't put any dishes in the microwave with something like popcorn because they retain more heat and have nothing to transfer the heat too. If you mean the built in spinning plate that you set stuff on and you have an older model the fan might be broken. Something similar happened to my microwave as it is pretty old i just removed the panels and cleaned everything/blew it off with an air hose and it started working again. I'd check with the manufacturers also!
Sep 25, 2012 | Panasonic NN-T694SF Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
I self cleaned oven and at end f cycle the dor is still locked and the touch pad for the oven is not working. The microwave touch pad is working fine. I tried to rest breaker but the problem did not go...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Apr 30, 2011 | Microwave Ovens
I have a range master 110 clasic 2007 when the small oven was switched on a fan would come on. my engineer says that this model has no fan because it is gas.
I have a Rangemaster and like yours is dual fuel. Gas hob and electric oven. The large oven is fan assisted but the small oven, on the right hand side of the range) is self cleaning and not fan assisted.
Hope that helps.
http://www.pricerunner.co.uk/sp/rangemaster_classic_110.html
Mar 31, 2011 | Microwave Ovens
Jenn-Air Microwave Oven (JMC8130DDB) is dead. CB in Main (Box) is OK. Microwave is mounted in a wall cabinet over a Jenn-Air electric self clean Oven. Oven was in "self-clean" when the Microwave...
Hi!
I read your comment about needing to remove the control board to inspect it for damage. Looking at the diag. below, all you need to do is open the oven door and remove the two screws (#2 on diag.) fastening the brackets that hold the board in place and you can take it from there.
Refer to the diag. below If it was me, I would start by turning the breakers for both ovens OFF, then, in getting someone to help me pull the oven out, disconnect the power cord and check the power circuit protection devices like the fuse #4, located above the fan and the power board #25 also located on the back of the unit. Before replacing the blown fuse, inspect the wiring, If the unit is mounted over an oven that was in the Self Cleaning Mode that reaches temps. of about 500 degrees, there is a chance that a wire's insulation melted and shorted the unit.
If you need better resolution and the names and prices of the components on these diagrams, click on the following links: for the first diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00001?blt=06&prst=0&shdMod=JMC8130DDB for the second diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00004?blt=06&prst=0&shdMod=JMC8130DDB
I hope this info is helpful to you. If you need further assistance, just place a comment.
Mar 02, 2011 | Jenn-Air JMC8130DD Microwave Oven
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
Nov 26, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave will no longer heat. Model #MA-1000W
So we can help you, please post a NEW question, and please include your model number MA-1000Was well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar MA-1011 Microwave Oven
Jenn-Air JMV8208AAS Microwave Oven Logo
75 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
