Question about Dell Latitude C610 Notebook
My wifi says limited or no connectivity. How can i fix it?
PLEASE PLEASE HELP! I have tried everything turn it off, reseting the wifi, restoring my computer nothning works! PLEASE HELP ME!
    Problem Solver:
  • 7 Answers
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Posted on Nov 14, 2011
  • 57 Answers
There can be many possible issues here. So if you do not find the answer on the first try you should post what you have tried already. That said...
has your connection worked with this same equipment in the past?
If so I would unplug all devices from the wall and power off your computer. Then power up each, one at a time. Start with your modem, next router, next computer.
If still no connection, You should be sure your modem is connecting to the internet, by eliminating the router. Use an ethernet cable directly to computer. re-powering all devices with each con figuration.
If you do have a connection w/o the router then I would reset the router by using a paperclip to press the rest button on the back. this will reset it back to factory defaults.
Again re-power all devices and let us know how it goes.
Andy
Posted on Sep 10, 2009
    Brigadier General:
  • 10,406 Answers
Straighten-out a paper-clip.
Push one end inside the pin-hole in the back of the router,
and hold for 2 seconds.
This will "reset" the router to "factory" settings.
Then, follow the instructions that came with the router
to do the "first-time" setup of the router.
Testimonial: "a paperclip seriously? and wat if i break it? "
How do i fix my ipad?keeps saying .. ipad not set up and that needs wifi but it still doesnt work,????
Connect to computer with iTunes on it and try a reset if that doesn't work do a restore...you will lose your data. If that doesn't work your iPad is probably suffering from an internal error and needs repair or replacement.
Aug 15, 2016 | Apple iPad (16 GB) WiFi Tablet PC
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Lenovo Laptop won't connect to internet?
Might be your wifi adapter has failed try installing external wifi us \b card
Dec 02, 2015 | Lenovo Computers & Internet
How would i fix the Wifi on my Zeepad? The Wifi will not work at ALL i have done 2 factory resets
I had the same problem. On a Hisense tablet. My daughter fixed it she didn't give up her secret but she downloaded an android firmware app. I believe that may have solved my problem. Believe me I tried everything before she took it home
Apr 06, 2015 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
None of my wifi devices connect to my Huawei E5220 mobile wifi. How do fix this problem? It keeps giving authentication problem
if its about authentication than your putting the password wrong. also i think your limited on the devices you can connect to it . if im not mistaken its like 4
Aug 11, 2014 | Huawei Computers & Internet
My iphone 5 and iphone 5s cannot connect to wifi
Do they work on any other wifi networks? If you haven't tried this try this first of all. If it works on other networks but not your own then call your internet service provider. Try to connect other devices to your network - If non-Apple devices connect then your wifi security settings might need to be upgraded.
If they are working on other networks:
Try to turn on airplane mode by going into Settings > Airplane Mode. Leave it on for at least 10 seconds.
If that doesn't work try to reset your network settings. Go to Settings > General > Reset > Reset Network Settings.
Still not working? Next try a restore to factory settings. First, back up all your information. I recommend a backup through iTunes as well as making sure your pictures/contacts have another backup. If this is a software issue you won't be able to restore your iPhone from a backup, it will bring the glitch back. Plug it into a computer with the newest form of iTunes - click on the restore iPhone button. When you test out the phone, do not restore from backup. If the problem is still there you have a hardware issue.
Apple stores and the Apple help line can run a diagnostic to see if you have a wifi hardware issue too. If you have a hardware issue you can get them to fix it (free if it's in warranty) or try to take it apart and replace the parts yourself. This does void the warranty.
Mar 14, 2014 | Tablets & eReaders
Authentication problem for wifi on LG-P750g
Try to launch a hard reset on your self-phone by following these steps:
1.If the device is off, hold down the Power button to turn it back on.
2.Afterawrds from Main Menu find and select Settings.
3.Then open the Backup&Reset (Privacy) folder and select Factory Data Reset.
4.Tap Reset Phone and read the warning when it pops up.
5.Choose Erase Everything and the phone will begin restoring.
6.Well done! The hard reset has just been performed.
Hard reset usually solves those issues.Hope i helped
Aug 22, 2017 | Computers & Internet
My wifi keep saying disconnected this phone is not on I just let my son use the phone to download apps I reseted everything because it was not working right yesterday and now i can't get the wifi back
try this solution...
1. select "airplane mode" to disable all wireless connection then turn off your phone.
2. turn on your phone then disable "airplane mode"
3. turn on your wifi now.
Mar 05, 2013 | Cell Phones
Dell Latitude C610 Notebook Logo
986 people viewed this question
Alun Cox
