Question about Brother MFC 210C All-In-One InkJet Printer
Unable to clean
My display says unable to clean see troubleshooting and routine maintance in users manual. no code
I tired menu *2864 still says same thing, no code and now all the lights are blinking.
  • 2 more comments
  • yngbld Dec 10, 2007
    Tried the 8 then 0 all that happened is it now says
    00:15 21:56 ok and the lights are still blinking and I still can't use it.
  • Joseph Betinol Dec 17, 2007
    unable to clean
    my printer mfc-210c appear in lcd display unable to clean how to fix this problem...
  • milly47 May 24, 2008
    My printer is saying un able to clean see manual but i no longer have it was given to me without the manual by another person.
Hi, I tried the solution above "by obiewan" it work's for me but I do a little changes on his pattern.
1. Unplug your printer
2. press down the menu/set then plug it (just keep oh pressing it down until you see the message error 46 show up on LCD)
3. press 80
4. then look for "Purge", i think its on the 25th when you scroll down
5. then reset the pruge count to "0" by pressing 2 7 8 3
6. then press stop/exit
7. then press 9 twice
VOILA!!!
Posted on Jul 16, 2008
  • copper_doodl
    copper_doodl May 21, 2012
    Thank you so much naldz4. This worked great on my MFC420cn all in one.
Hi! I am new here and I just want to thank whoever it is who posted re: resetting my printer. My printer keeps on showing the "unable to clean" message. I thought it was a hopeless case already but when I tried the steps on how to deal with "error 46", my printer suddenly worked. so to all of you guys who are getting the message "unable to clean", just follow the simple steps of
3. press 80
5. then reset the pruge count to "0" by pressing 2,8,6,4
voila!!! then you're all set. hope this helps. pls double check my step number 5 in other posts if this is the correct numbers to enter, just to make sure :)
Posted on Jun 25, 2008
I have the same probolem as obove but will not work on ;my printer. Where is the wasitank?
Posted on Dec 13, 2007
  • 832 Answers
Welcome to maintenace mode!
You have entered it.
Now you have to press 8 then 0 then several times start BK copy until you reach PURGE XXXX (where X is a no.) . Press 2 then 7 then 8 then 3. Purge should show 0000. press stop then 9 then 9 machine should come up normal mode.
DID YOU CHANGE THE WAISTINK TANK?
IF NOT YOU WILL CAUSE SERIOUS DAMAGE TO THE MACHINE!
Posted on Dec 10, 2007
  • Mix-it-up
    Mix-it-up Dec 10, 2007
    As I wrote: 8 then Zero THEN start bk copy SEVERAL TIMES start bk copy to sitch further until...(plz read first post for the rest!)
"clean unable 46 " and see troubleshooting and routine maintenance chapter in users guide.
HI Gail,
Please watch this brother problem related video and solve your problem.
Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother DCP 165C Compact Color Inkjet...
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Hi I have a Brother DCP 130 MFC I have an error message clean unable 4f see troubleshooting maintance chapter in user guide
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
All the Best Pineworks
Mar 02, 2010 | Brother MFC 420CN All-In-One InkJet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-5840CN
Press Menu, * 2864. That puts in in maintenance mode. If it flashes error 48, the flat ribbon to your head is broken. You'll need to replace the entire head assembly. Press 99 to leave the maintenance mode.
Jul 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
well tuaman I had a customer that had the same prombelm and it was that he had forgotten to download the driver for the troubleshooting operation and cleaners of the disc maybe that is the same promblem have you thought about you mite have not install the whole drivers disc and that mite be the prombelm ?
lala linda
Jun 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Will not print
What 2 digit error code does the machine display, too?
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
637 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
