Question about Coleman Mach III Air Conditioner
Colman unit is getting no power
I am getting 110 power to the computer board from the breaker and 12 from the thermostat but nothing is coming on. Replaced the computer board and have the same problem. This is a Colman unit with the thermostat on the wall. Any ideas?
    Guru:
  • 588 Answers
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Sep 11, 2009
Testimonial: "I called the people at www.rvcomfort.com and they are very nice and helpful."
I have a problem with a state 30 gallon hot water heater,the tank states 240 v but there was only 120 running it ,it has one element ,everything was working until the outside water well pump quit since the...
Thermostat is rated 120-208-240-277 volts.
Element will work with any voltage too, no matter rating on label. It will burn at different temperatures at different voltaGES.
Any voltage should run water heater.
Copy following links:
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Push in reset button.
Make sure tank was full of water before turning power ON. Or element will instantly burn out.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Are you testing voltage across top two screws on element.
http://waterheatertimer.org/images/Upper-thermostat-w-wire-a-2.jpg
Or are you testing each leg to ground?
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
Oct 31, 2013 | Water Heaters
Thermostat needs replaced
To replace a thermostat, you will need at least: 1. A new thermostat 2. Screwdriver 2. Needle-nosed pliers. Depending on the thermostat and location in your home, you may need more. Make sure the new thermostat you are using to replace the old one with is compatible to your 110-volt housing circuitry. Always turn off the electrical power to the home thermostat at the power panel or circuit breaker box.--------------------------------------------------------------------------
carbrain c168 scanner
Dec 01, 2012 | 1996 Pontiac Grand Am
The thermostat clicks but nothing else happens, no a/c will come out or no heat [I tried both]
(I have this model at my home). If you switch it over to emergency heat and nothing comes out then check the breakers behind the panel for the air handler (inside unit)
There may be other issues, mine had a sequencer which had come apart. The newer
sequencers have a retainer clip to prevent this. It is located under the galvanized cover inside the indoor unit next to the transformer.
Also check the breakers at the main panel (there should be two double breakers, one should be a 20 to 25 amp for the outside unit and the other should be around 70 amps for the indoor unit). Fully reset them after performing checks described later. .
If your outdoor condensor compressor is failing (as mine did), it will trip the smaller breaker, if your indoor unit has a short or other problem it will trip either the 50 or the 70 amp breaker. Make sure you turn off all breakers before inspecting.
One last thought, if your thermostat has battery backup and the transformer has failed, you will still hear the click but nothing will operate
since the 24 volt transformer operates both the indoor and outdoor units.
It is located under the galvanized cover inside the indoor unit.
(I would suspect this if all else appears normal with no breakers tripped). A universal transformer is around 8 to 12 dollars make sure to use the 240 volt wire and the COM
when installing it. (there are several wires for various input voltages on the primary).
they are available at any HVAC parts store. Power off to all sources before repairs.
Aug 10, 2011 | Intertherm Heating & Cooling
My honeywell RTH230B won't do anything. I put fresh batteries in it, tried everything and nothing happens. What is the probelem and what can I do?
If this is a typical air handler unit then turn the fan switch to on, if the fan does not come on then you have a control problem or no power to unit. Check fuses/Breaker.
If fuses and breaker are ok then try this. Turn the power off to unit, try and locate control board usually
located in the lower panel where the blower might be.
Disconnect thermostat wires that go to probably
r/w/g/y/c and remember what color goes to where.
If you can make a jumper wire or you have aligator
clips, jumper r and w. Put door back on, turn power on and heat should start up.
You can also put a jumper between r ang g terminals
instead and the fan should come on.
If either of the two cases happen, then you need another thermostat or check wiring to thermostat.
Another possibility is that there could be a car fuse
located in the control board that is blown
Good Luck
Jan 12, 2010 | Honeywell Programmable Thermostat Heater
Wiring issue on a 1965 Roadrunner Travel Trailer
Generic comments follow:
I'm not real clear on what you are asking ... I can almost guarantee you that you will not find a wiring diagram for your trailer.
Your travel trailer operates on 12 V DC. Your frig, the heater, all the lights, radio, all 12 volts. Your running lights should be getting power from the tow vehicle. While towing, the tow vehicle should be charging the battery. You may find some 110 volt lights inside, but probably not. To keep your battery charged, you have 110 Volt AC power coming in. Your frig may run on 110 V AC but it still needs 12 volts for control. Your Air Cond and Microwave and TV (if equipped) will al,so run on 110.
Regarding the three wires from the battery, there should be a battery charger close by your 12 Volt fuse panel. Even though the trailer is a "vehicle" dont depend on using the frame as a ground like you would in a car. So, that accounts for two of the three - a red or black and a white wire. There may be some dedicated line that the battery supplied to account for the third wire.
There should be a emergency breakaway switch on the front of the trailer. This is a switch with a pull pin. If the trailer breaks away, the pin is pulled out by the tow vehicle and the electric brakes should be automatiocally applied to stop the trailer. This switch should be powered, unfused, directly from the traailer battery and go directly to the electric brakes - presuming you have this feature.
Be aware, this trailer power supply was built and designed for a life style far different from that we enjoy today. If you have a 30 amp cord, as I suspect, 30 amps is enough to charge your battery, run your 12 volt items, run a TV and AC or TV and Micro or Micro and AC but not much else. As you are aware, you have two circuits built with #12 and they are probably protected with a 15 amp breaker though the #12 would be protected with 20 amp breaker in a house. The cord is only rated for 30 amps and it may be tired, unless you have replaced it.
I hope I have provided a little insight to your situation. If I can be of further assistance, please let me know.
a
Sep 20, 2009 | General Electric GE INDUSTRIAL SYSTEMS...
RUUD Air Conditioner not turning on
Need to check the breaker to the unit at the electrical breaker box. You should have a dual 60 amp breaker that runs the unit. Also if you removed the front of the furnance on the inside the system will not work unless the front of the furnance is on. There is a safety switch that will not allow the system to run with the door off. There could be the problem if the breaker is on and electricity is supplied to the unit that switch may be out and need replacing. The furnance is operated on 110 volts the condensor (outside section) operates on 240v you need to insure that the proper voltage is supplied to both.
Since both units work together yet operate seperately if the furnance comes on and the condensor doesn't then there is an electrical problem at the condensor (more than likely the contactor switch) if the condensor comes on and not the furnance then there to is an electrical problem (either 110 volts not supplied) or the switch to the safety cut off is bad. Now if neither furnance nor condensor comes on there could be improper power to both or a bad thermostat since the thermostat activates both furnance and condensor. Good Luck on repairs
Dave
Sep 04, 2009 | Ruud UBHC Air Conditioner
Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Heater and AC run even though thermostat is off
It sounds like you have a short in the control unit at the ceiling pack. Remove the inner shroud from the AC and pull down the control unit. Remove the cover from the control unit to access the relays. With the thermostat off, check for power at the white (or orange depending on the unit) wire coming from the thermostat to the relay board. Also check power from the yellow and gray wires from the thermostat to the control board. None of these should be hot with the thermostat off. If there is power then you have a short in the wiring between the tstat and the upper unit. If there is no power, then you have a bad control board.
Hope this helps,
Jeff
Rate please!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Problem, no heat
The fuse is a 110 volt breaker in your service panel. If your heat comes from the heat strip it is inside of the ac in front of the evaporator. If it is a heat pump thats the the compressor. To create heat the compressor runs in reverse. There is a directional relay operated by the circuit board and thermostat to tell the ac what you are calling for, heat or ac. The heat strip is connected to the circuit board and is also operated on 110 volts. You have one of three problems. Breaker tripped, bad heat strip, bad circuit board. Possibilities, find the heat strip cable and unplug and plug it back in a few times,maybe lost connection. That happens at times because of the warm and cold elimates. The heat strip can be tested by takeing it out and bench testing it with 110 power. circuit board can be checked by use of a volt meter, turn the ac to heat and check the pins where the heat strip plugs in. To chech the heat pump you must go up top, remove ac cover and with an amp clamp find the wires going to the compressor and put the amp clamp on one wire only. Amps should be no more than 7 amps. If it is the compressor is shot. If there is no reading then the compressor is not running. Now you may have a bad capacitor which is up top under a sheet metal cover. They also can be tested with a VOM. You will find 2 or 3 capacitors depending on model. Run and start. Capacitors typically are charged with 370 to 600 Volts. They will knock off the top of your camper. BE AWARE OF THE FACT YOU ARE DEALING WITH 110 VOLTS. IF YOU ARE NOT FAMILIAR OR COMFORTABLE GET SOME QUALIFIED HELP. GOOD LUCK
Mar 14, 2009 | Coleman Mach III Air Conditioner
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Coleman Mach III Air Conditioner Logo
352 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
