Question about HP LaserJet 1020 Printer
The printer prints with a smudged black line the length of the left margin of the page.
    Problem Solver:
  • 23 Answers
We recommend replacing the cartridge as a first step. If that does not correct the problem, we look for toner dust inside the printer. DO NOT VACUUM this dust as it is very fine and will go through your vac bag and create dust everywhere. Finally we look for finger prints and pieces of paper.
If the toner is able to be rubbed off the paper, it is a fuser issue. Replacement of the fuser will be needed.
Posted on Sep 10, 2009
I am trying to print on forms that are tractor fed and are 8 X 5 1/2, how do I adjust the printer so it will print on this size form. How do I adjust the printer to this size. I have already adjusted in...
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box left.right.top.bottom also you might select print preview where you can look at the size and detail of the document you are about to print
hope this helps
Nov 24, 2010 | Office Equipment & Supplies
My HP LaserJet 2430n prints black smudge lines down the left side of the page. How can I correct this?
check the fusing unit in the rear of the printer and check your print cartridge for smudges.
Sep 28, 2009 | HP LaserJet 2430dtn Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Prints a 1/8 inch or so smudge in left margin on most of the page.
check the Page Setup from file Menu, adjust your desired margin or printer margin.
Dec 03, 2008 | Office Equipment & Supplies
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Lines along edge of paper
1 of 3 things I can think of off top of my head.
Since they are straight, I would suspect the transfer unit.
If it were just one color it would be that imaging unit.
Unlikely the fuser.
It doesn't sound line an issue called bar coding ,where the machine prints random lines. That would be a software issue.
Take the transfer unit out and inspect it for the marks.
I am assuming the streaks are on all colors correct?
If it isn't on the transfer belt, and on all colors check the fuser and see if its latched.
Jan 16, 2008 | Xerox Phaser 7400DN Laser Printer
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
162 people viewed this question
Seeker5211
Seeker5211
