i want to connect mypowered philips subwoofer to my subwoofer connection this subwoofer has a 15 pin female connection i need to rewire this subwoofer can you tell me how to do this?
Comments:
Sep 10, 2009
- i just want the sub woofer to work what colored wires to i need to connect just to make the powered subwoofer to work thanking you in advance for any solution
Sep 11, 2009
- i have a philips powered sub woofer i want to connect this subwoofer to me awia d57 receiver i need to re wire this subwoofer so i can connect it to my receiver.i want to know what wires from the 15 pin female connector do i connect to a two wire male connector. the model of the subwoofer is a philips mcd288 thank you in advance for the solution
Sep 11, 2009
- THE MODEL NUMBER OF THE SUB-WOOFER IS PHILIPS MCD-288
Im assuming you have AV-D57 5.1 channels receiver which is not compatible with many other sub speaker systems without rigging the system unless it has male rca jack and power woofer. your 5 pins Phillips sub-woofer has 5pin plug is not adaptable to your Aiwasystem unless the sub has an rca male jack. In the back of your Aiwa Receiver you will see a rca femal jack for you sub-woofer connection, it should be #10 female jack counting from left to right and printed on the back of your receiver as a SUB WOOFER. In order for your phillips 5pin sub-woofer to work on that channel is that you have to find the right two wires positive and negative from your speaker and wire rca jack using soldering gun to connect rca jack to you phillip sub woofer speakers, next I believe out of that five pin it also has the power supply to your sub woofer which you also have to make a power supply to the sub. You better off getting a correct type of sub to work with your nice unit. If your sub is compatible, than your receiver would also have a 5pin plug in.
Red, Yellow wires would be positive voltage Black,Copper, and Solid green would be negative ground wires Green brown pink, orange, blue, purple, would be speaker input wires
The receiver use to turn on but then turn off randomly, ant the little ECO led light would come on....
(More)
The receiver use to turn on but then turn off randomly, ant the little ECO led light would come on. But the receiver wound not turn back on. The only way you could get it back on is yo unplug and plug it back in. So i opened it and messed with the main wires going to the front panel i unpluged them and pluged them back in a couple of times and it would turn on but then turn back off. Now i think i did something Because the ECO light wont turn on it makes no sound when i plug it in nothing happens. if anyone could help that would be really great thtank you
