Question about Black & Decker TCM830
Brewing cycle My TCM 830 stops brewing before all the water is used up in the reservoir. It brews about 3 cups at a time, then quits. I have to keep pressing the brew button to get a full pot.
  • clogged Dec 21, 2007
    We are having the same frustrating problem with our TCM830. It has gotten do bad that we have to press the on button at least 8 times to brew the whole pot. It's very annoying to have to babysit the coffeemaker and coax it along to finish brewing. It's on 6 months old. What's the solution to remedy this?
  • Anonymous Mar 02, 2008
    I purchased the TCM830 14 months ago, now its stops brewing before all the water is gone. It only brews 2-3 cups and stops. What is the solution to this problem?
  • 70 Answers
The thermostat is proably faulty and makes the machine cut off early. Or it could be that your machine is getting too hot and the thermostat is cutting it off at the temperature when it is supposed to. No repairable parts inside. But a new one. Do not hold start button in. Machine can get very hot.
Posted on Aug 06, 2009
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Vinegar solution cleans mr coffee modelJWX23 but can it be taken apart to clean it better the coffee doesn't come out real fast for long
No. This coffeemaker is not built to be serviceable in that regard.
You can wipe down the inner-sides of the reservoir for a slightly better maintenance cleaning. But, 4 cups of pure white vinegar (no water added) in the hour-long cleaning cycle followed by two pots of fresh water in the brewing cycle is really the best way to clean the rest of the inner-parts which contact the liquids.
If your real purpose for your question is how to resolve the elongated brewing times, I'm afraid that is a symptom of damage to the heating element. This too is not serviceable.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is one, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
You can get a faster brew cycle by putting warm water into the reservoir and making coffee right away. But, depending on your hot water supply, the coffee may not taste quite as good.
Jan 10, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
To begin, you will need the following:
  • 48 ounces of undiluted white vinegar
  • Large ceramic mug (do not use a paper cup)
  • Access to an empty sink
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Braun Flavor Select will not brew coffee.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
corvette2
Nov 16, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Black & Decker TCM830 Logo
172 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
