Question about Car Audio & Video
How to install a amplifier bose in my 2005 chevy sylverado wiring?
  • 376 Answers
If it has factory bose system, you will need a aftermarket converter box for bose systems, from there most should be able to finish it out.
Posted on Sep 11, 2009
How do I bypass the factory stereo amplifier?
Remove radio from dash. Unplug wires to factory amp. Install wires to your new amp. Reinstall radio.
May 21, 2014 | 2002 Chevrolet TrailBlazer
Wiring color code radio
Here is what I show from the manual.
2005 Hummer H2 Car Audio Installation Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the Center Console or Behind the Glove Box
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 01, 2014 | 2005 Hummer H2
Amp color code wire diagram 2002 tahoe
I just built a factory amplifier/crossover bypass adapter for my 2002 Chevy Tahoe Z71 (non-Bose system) . This adapter will allow the full range of audio directly from your head unit to the door speakers. Without this adapter, the factory amplifier will cut out much of the bass / low frequency audio to the door speakers. This adapter will continue to provide an audio signal to the factory amplifier for the rear factory subwoofer and cargo area pillar speakers.
I have posted an article with complete set of step-by-step instructions and detailed photos of the build and installation process.
http://www.savagehomeautomation.com
The article also includes direct links to the exact parts that I purchased on Amazon to build this bypass adapter.
This is what the end result looks like. It is a 100% non-destructive adapter than can be installed or removed from the Tahoe at any time. It just plugs in between the factory wiring harness and the factory amplifier.7_9_2012_1_38_07_pm.png
Good Luck!
Feb 01, 2012 | Cars & Trucks
2005 Chevy Silverado Bose stereo operators manual, how do I set the EQ presets?
My left front speaker sounds distorted at low volume but sounds ok when I turn up the volume.2005 Chevy silverado bose stereo and speakers
Apr 30, 2010 | OEM Systems Car Audio & Video
Part number for a radio amplifier 2005 320e cdi
mercedes Part# A2098200889
for bose systems works with fiberoptic cd changer
Mar 31, 2010 | Car Audio & Video
Radio works but no audio. 2005 chevy silverado
check to see if you have bose audio, it will say bose on the door panel speaker grills - if you do the most common failure is the amplifer located in the center console.
Jul 15, 2009 | 2005 Chevrolet Silverado
2005 chevy silverado stereo wiring diagram
Are you trying to install a new stereo? If so will need to re-wire all your speakers because of the bose system.
And if im not mistaken your year truck might need a really expensive harness to install the radio. Here is a link to it.
http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?tp=3486
You should look into this too! http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?
May 22, 2009 | Car Audio & Video
Bose amlifier
Power wire is usually yellow or red. A cheap test light from the parts store will tell you. The remote wire is almost alway solid blue. A volt meter will tell you for sure. Remember,the remote wire is very low voltage.
May 18, 2009 | Infinity 475A Car Audio Amplifier
Car amplifier instalation
ur doin too much...you only use two amps to run a common subwoofer...if you want two subs either hook them both up to the amp you have, or get a bigger amp...hopefully this helps
Jan 27, 2009 | Car Audio & Video
'05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
