Question about LaCie d2 DVD-RW Burner
DVD+RW problem After burning onto  a Tevion DVD+RW disc, I was able to read the data okay. The next day the disc could not be recognised in any way. I'm using Toast 7 and when entering 'disc info' I get the caption: 'There is no disc in the recorder'. The disc does not exist to my powerbook drive either. I have probably burned to this disc before and erased successfully. I also have 4 other discs of this type and none of these will work either now, whereas they all did before. What can I do to resolve this please in simple terms!?
  • hereiam Dec 11, 2007
    Thank you for your reply. I don't think there is a burn speed with the Lacie d2 DVD RW burner. I just drag the files in and 'Toast' them, and I always verify afterwards.
    I'm wondering if the Tevion discs aren't very reliable, or perhaps I need to update the drives firmware but I couldn't find any links that on the Lacie site.
  • 749 Answers
When burning CD/DVD use a lower burning method... as not to rush data to burn and make sure that before burning the let it verify or test the data burned on the CD/DVD... it takes time, but be patient, after all it is your data.
Posted on Dec 11, 2007
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
DMR-EZ48V does not recognise Sony DVD+RW disks
Hello
If there are some writing errors in data, or sctraches, Sony sets won't read the disc well; especially to DVD+RW discs. OK.
Apr 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I copy the mini disc onto a dvd disc, is there a converter program I need to download so that I can then burn several mini discs onto a 2 hour dvd?
Hi, You can convert mini disc ( 8 cm diameter ) to a standard DVD disc via your PC. Please follow this steps : 1. Install your canon software/driver in PC 2. Install DVD creator in PC ( common software is use Nero scout) 3. Download your mini disc data to PC 4. Enhanced your data with Nero 5. Burn your data to standard DVD
Make sure you have DVD RW hardware in your PC.
Dec 04, 2010 | Canon DC210 DVD Camcorder
DVD burning on Seimens Li Amillo Laptop
When you are finished burning a disk you have to make sure you finalize the disk.
Nov 28, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
My DVD RW does not recognise the disc as being loaded
You need to buy software to burn DVD's A dvd drive will not burn DVD's on it's own.
Nov 11, 2008 | Maxell - DVD-R - 1 x 120min (567613) Media
DVD RW reading problem
Ok it seems as if the drive may be dying or is dead. You said you used these disc before so the problem is with the media(disc) its with the medium*the drive) I dont think flashing the firware in this case will hely you will need to replace the drive :)
Dec 11, 2007 | LaCie d2 DVD-RW Burner
Wont burn data dvd
dear
i have this kind of drive ( 7W036-A01) , IT READ AND WRITE CD BUT IT COULDNT WRITE DVD ( EVEN IT READ DVD IN GOOD WAY )
PLEASE CAN ANY ONE HELP ?????
Jul 31, 2007 | Dell (7W036) DVD+RW Burner
LaCie d2 DVD-RW Burner Logo
113 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
