Turn it off and then on after 20 minutes and see if the problem goes away.
If not then inspect the compressor area for any loose or broken wires.
Next step is to check the compressor relay. It is mounted on the side of the compressor. Replace the relay if found faulty.
If relay is OK then the compressor is stalled and needs to be checked and replaced. Refer to a an authorized service technician if you are unsure about how to test for faults and compressor replacement.
ge gss20iep suddenly stopped cooling.....fridge has power interior lights on ..... beleive defrost...
(More)
GE GSS20IEP suddenly stopped cooling.....fridge has power interior lights on ..... beleive defrost timer is bad ? thoughts .....
my ge side by side refrigerator keeps stopping for periods of time, ice cream melts and then its...
(More)
my ge side by side refrigerator keeps stopping for periods of time, ice cream melts and then its starts running again on its own. This is the second refridgerator of this type I have owned in the last three years, had the same problem with the previous one (only 2 years old). Why?
ge profile side by side - freezer nor refrig is getting cold - about a month ago the freezer had ice...
(More)
ge profile side by side - freezer nor refrig is getting cold - about a month ago the freezer had ice acclumated a the bottom - i reset the breaker - no water coming out the dispenser
