Question about Canon GP-200 All-In-One Printer
I have a canon gp 200 and when i want to duplex copy, 2 sided-2sided, it tells me to remove the paper from the duplexing unit, yet there is no paper....
I have a gp 405 error 051 pleace help me
The error code E051 deals with the duplex jogger arms.... Mostly,it is saying that when you are duplexing the arms that move to keep the paper straight in the duplex unit are not moving correctly. It is the motor and saw tooth gears. It is located above the paper feed unit.... Good Luck
Sep 12, 2011 | Canon imageRUNNER 400S Copier
Hi. I have a Canon IR2018 printer in my office. Because I am eco-wise I would like to set it from single to double sided printing (I think that's the term for printing on both sides of the paper) but...
you can do so if your machine has a duplex unit attached.if it has a duplex unit then for printing you have to select 2 sided profile as default or for prints when u want double sided from you pc print software(canon) or the server if you have one .that way u will get all the prints in 2 sided. for copying u have to select 2 -2 sided by pressing the 2sided key on the console of the copier.then place the originals in the ADF and thats all
Jul 15, 2011 | Canon imageRUNNER 210S Copier
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
Nov 17, 2010 | Konica Minolta Magicolor 5450 Printer
Canon IR1018 forces duplexing
Go to service mode MENU and #, clear all and ok,
after that machine goes to factory sett., reenter your sett. it should work
Jul 08, 2009 | Canon Duplex Automatic Document Feeder
How to make automatic duble sided copy on IR-2000
these machines have a duplex unit all machines this size does, now a duplex unit is where the paper double sides in the machine, like doing a double sided copy.
i know off some people think that a duplex unit is the DADF (document feeder).
May 31, 2009 | Canon imageRUNNER 5570 Copier
Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Mar 06, 2009 | Panasonic Workio DP-3530 Copier
False jamming at duplex unit
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Feb 21, 2009 | Canon NP 6050 Copier
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
70 people viewed this question
old marine
old marine
