My printer wont install i have tryed everything 8 hrs up untill 2am last night
  • 1 more comment
  • peck831 Sep 11, 2009
    dont have a cd
  • Jim Thurston May 11, 2010
    Have you tried to go to www.hp.com Click support and drivers. Click dowload drivers and software, then let hp find your hardware by clicking "start detection"? This has worked for me. Good luck.
    Sergeant:
    Champion:
  • 249 Answers
Disconnect all the cables.
Uninstall the drivers using the CD.
Reinstall the drivers and plug the cables when prompted.Make the printer online through Control panel.
Posted on Sep 10, 2009
My defy front loader filled up with water at 2am last night while not in use...flooding my kitchen. the machine tap is always left open, but is active only when the machine has been switched on???
the water inlet valve is faulty and is not closing fully when powered off causing a small but constant stream of water coming into the machine until it floods out the front, you will need to replace the water inlet valve, in the meantime turn the taps off when your not using it
Feb 10, 2017 | Washing Machines
Recently installed Intex saltwater system, all of a sudden, have green forming around walls of pool. All levels look okay; except chlorine is a little low and PH is very high...I ran the boost cycle last...
Once you get the "Green" stuff on the walls, you must brush it off.. and one boost cycle will not do.... Make sure you have the correct salt level!!! Keep in mind..big pools can take up to 350 lbs of salt... Now...set you pump at 12 hrs and you chlorinator at 10 hrs between those 12 hrs.. Run this cycle and you should see results within 2 to 3 days... Clean you filter and rinse your electrolytic cell after 3 days because you will have dead algae. After the water turns clear, you can then lower your cycle to 10 pump and 8 chlorinate.. Good luck! hope this helps!
Jul 19, 2011 | Intex Automatic Salt Water System for ...
Hi, I have an Asus PRO50G laptop. Last night I shut it down before going to bed and assumed that it had shut down successfully, but when I awoke I found that the laptop had run itself out of battery while...
Since the battery totally ran out, hence, now you require to charge it back up kindly do not try to switch on your laptop any more unless you have left it on charger for a minimum of 8 hrs. In case even after charging for 8 hrs it is doing the same thing i.e. logging off then, press f8 key while booting up and from the selection select last good known configuration and hit enter. That will fix everything. In few cases it's also f10 button hence try both f8 and f10.
Mar 19, 2011 | ASUS Computers & Internet
I have a samsung syncmaster 204T monitor. Everything was fine until last night when i kept my system on standby for approx 5-6 hrs. Now whenever i start my system there is only a green led on front panel...
I just started having the same problem! The green light flashes, but the monitor is blank. None of the button work (menu, source, etc...) and nothing changes when I disconnect it from the computer. I was suspecting a bad graphics card at first, but now I'm thinking the monitor itself is bad?!
Jun 29, 2010 | Samsung SyncMaster 204T Monitor
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
Wont start after setting
Remove air cleaner Spray carb with carburetor cleaner inside and out let dry try to start..
Probable cause dirty carb or air cleaner choke not set properly or needs adjustment
and cleaned>>Charg battery ans check fluid level fill only with distilled water
Jan 30, 2009 | 1997 Chevrolet Suburban
My Samsung BD-P1400 is frozen on "load" and disc tray won't open
My player worked fine couple of days ago, then last night when powered up, message was "load" and it stayed like this forever, and tray open would not work. Tried everything, nothing worked. Left unplugged from power for 24 hrs and bingo everything worked as should. I suspect that the unit is still trying to load info from last disc which I stopped in the middle of some bonus material, even though the disc was no longer in the tray.
Dec 26, 2008 | Samsung BD-P1400 Blu-Ray Player
My roadmate 700 wont pick up sattalite until 1 or 2am
Install this update and take out into a clear, open area to create initial SAT contact. This will set your location and map sat locations closest to you.
http://www.magellangps.com/support/chooser.asp?prodid=955&supportid=529
Oct 13, 2008 | Magellan GPS
Problem installing HP printer all in one not solved-transscript below-PLEASE HELP!!
very easy..... first do not connect ur printer to ur pc..install driver until installation complete...than restart ur pc than connect ur printer...will thank on this... hahaha
Feb 08, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
24 people viewed this question
jasbo
jasbo
