Question about Quantaray QSX 9001TM Tripod with Built-in Removable Monopod
I broke the ''arm''/''directional control'' on my QSX 9502 TM. Can it be replaced?
1994 lower control arm broke at balljoint
What brand of car? Some brands have after market heavy duty replacements that are made from heavy duty tubing instead of the sheet metal pressings typical for factory parts.. We have seen them that failed due to the fact that pivot bushings wore completely through and into the pressed sheet metal that had been holding the bushings, and the wear through the sheet metal was progressing rapidly toward failure. Check all the other front end control arm components for similar progressive wear out. This kind of thing can be dangerous. It usually will give brake steer in inconsistent directions before failure.
Mar 21, 2015 | Cars & Trucks
Where can i find replacemet parts for my tri pod
Quantaray does not sell parts or repair thrir tripods. Sorry, get a new one.
May 06, 2014 | Quantaray QSX-DigiPro 8500 Tripod
Left front lower control arm broken in 2004 Honda Civic Hybrid
i would replace it, not easily done you need special tools
Feb 13, 2014 | 1993 Chevrolet C1500
Want to know the relationship between the rear trailing arm and the control arm. If you had the rear trailing arm fixed because of recall then 2 months later they say the control arm came loose and broke...
The recall for your vehicle may or may not have included replacement of the trailing arm. The recall says that the trailing arm is to be "inspected" then it will be replaced, or modified at the discresion of the person performing the inspection. If it was "replaced", it would require the control arms to be disconnected and reconnected. If it was only "modified" there would have been no disassembly of the control arms required. See the picture below. The picture shows the rear suspension parts. Notice that the upper control arm and the lower control arm bolt to the trailing arm. (which is what also houses the hub and bearing with the wheel speed sensor.) I hope this helps you to resolve your issue.
Mar 08, 2011 | 2003 Hyundai Santa Fe
Broke off the ice maker shut off arm. want to
Hi. Go to the site called sears parts direct. Enter the model number and see an excellent parts diagram. Order the part and u will have it in a couple of days. J.
Jul 30, 2010 | Amana ARB8057CSL Bottom Freezer...
Lost quick release Quantaray QSX 9002D
http://www.tripodquickrelease.com/Sunpak_Quick_Releases.htm
Apr 18, 2009 | Quantaray QSX-DigiPro 8500 Tripod
How to master clear the handphone 9502 beside
Sorry for having read your post that late. I think you have already sorted it out by now. Anyway, in order to hard reset the 9502 by hardware means, press and hold both the blue Fn and the green phone buttons, and, at the same time, press the reset pin with the stylus pen. A white screen will come up asking for confirmation. Just confirm it (with the left softkey, if I'm not mistaken).
Hope it works for you.
Cheers!
Carlos
Mar 10, 2009 | i-mate Ultimate 9502 Cell Phone
Broken Tripod
The Quanteray are private label made b Sunpak, which is a division of ToCad and ToCAd america-(973) 627-9600
Dec 23, 2008 | Quantaray QSX-DigiPro 8500 Tripod
Rear frame on arm to the axle
i believe your talking about the lower tourqe boxes. the lower control arm bolts to it. i dont know if they can be replaced or fixed, i do know summit racing has reinforcement plates by competition engineneering part #cee-8015. hoped this helps goodluck. QTRHRS
Sep 04, 2008 | 1990 Ford Mustang
Quantaray QSX 9001TM Tripod with Built-in Removable Monopod Logo
67 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
R.A. Ellis
R.A. Ellis
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
