Question about LaCie d2 DVD-RW Burner
Cd-dvd-rw drive problem
I have two drives both no older than 8 months i put a CD-R with backed up files on in this morning and both drives 1 : sony CRX320E cd-rw/dvd-rom 2 : Sony dvd-rw DW-D22A nothing happens, no icon appears in my computer, nothing these drives were working fine just yesterday, the drives are spinning disks up but nothing is happening? whats goin on? After burning onto  a Tevion DVD+RW disc, I was able to read the data. The next day the disc could not be even or be recognised in any way. I'm using Toast 7 and when entering ;disc info' I get the caption: 'There is no disc in the recorder'. The disc does not exist to my powerbook drive either. I have probably burned to this disc before and erased successfully. I also have 4 other discs of this type and none of these will work either now, whereas they all did before. What can I do to resolve this please in simple terms!?
  • Anonymous Jun 13, 2008
    MY LACIE D2 CDR/DVD BURNER ALL OF A SUDDEN WON'T RECOGNIZE
    THAT I HAVE JUST PUT IN A BLANK DISK.  USING TOAST 8 A MESSAGE SAYS THAT THERE IS NO DISK IN THE MACHINE.
    MY COMPUTER RECOGNIZES THE BURNER AND ALL CABLES ARE
    HOOKED UP PROPERLY. I HAVE BEEN USING THE BURNER SUCESSFULLY FOR OVER A YEAR. I  CAREFULLY SPRAYED SOME COMPRESSED AIR IN THE UNIT, BUT THIS DIDN'T HELP.
    -ELIOT
  • 2,427 Answers
Check your other post
Posted on Dec 30, 2007
I have a Pioneer CD/DVD Duplicator 8 drives. Recently no matter what disc I put in as the master. It tells me I have a mad Master Disc. Obviously all the media can't be bad. When this messgae pops...
The 3rd drive is the master now. If you want to change back to top drive, go to #8 "select source" and use up/down key change to " drive 1 " and save. for more detail, please read the user manual page 21 and 22.
For VPD system,if the top drive defected, the system should auto assign 2nd drive as source, but your system pick up 3rd drive as source drive, I suggest you check drive 1 and 2 before make copy.
Jan 04, 2011 | Pioneer 1 to 7 DVD Duplicator: SharkCopier...
I have a HP External USB CD/DVD R/RW drive. Stopped working.
First, try a new USB cable. Two, try a different USB port (if using a hub, directly connect to the computer). Three, check if there are any updated drivers or firmware for the drive.
(also make sure that the external drive is self-powered that the cord is undamaged and the power isn't surging or going into a brown-out. If it is one of the new bus-powered DVD drives, make sure that the computer has a good power source (not on battery for a laptop).)
Feb 27, 2010 | HP 8x External Double-Layer USB 2.0 DVD...
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
What did I do wrong? I copied doc files to a CD.
Is it a dvd-rom, dvd-rw, cd-rom, cd-rw?
What is the cd/dvd disk drive you are using?
(A dvd-rom, dvd-rw, cd-rom, cd-rw?)
This may be the problem.
Aug 22, 2009 | Compaq Computers & Internet
Emachine EL1200 won't burn dvd's.
I researched the Emachine EL1200 and it IS equipped with a DVD burner so there is no reason it shouldn't work. Return it while it is still under warranty. There is a 1 year warranty.
If it is out of warranty (system is older than 1 year), the drive can be replaced.
Aug 15, 2009 | E-Machines emachines (emachinees) CD-ROM...
I have Sony CD-RW and Sony DVD-RW - Nero will not copy files
Your DVD-RW needs to get repair from the authorised personnal.
Apr 23, 2009 | CD Technology DVD-R (44105)(100PK) 4x...
TSST corp CDRWDVD TSH492B - DVDCD-ROM drive not working
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
Apr 09, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Won't recognize blank dvd
Chek wtat is written on front panel
If it DVD-RW it can record only DVD-R blank, if it + so only +R
or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
Also chek the speed for you DVD and disk you using.
If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
Good Luck
Jan 10, 2009 | Microsoft Windows XP Professional With...
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
CD/DVD won't eject, won't play, Device Manager doesn't recognize.
If it's only 8 months old, then you have atleast 4 months left on your warranty. The problem will either be the ide controller channel or the dvd drive and firmware has faulted, the same fault probably happens when you have put a dvd in and it wont read or eject. Return to the place of purchase, where the drive should be replaced or the notebook exchanged.
Aug 11, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
LaCie d2 DVD-RW Burner Logo
147 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
