Question about Cycling
The switching gear change on the ack is the problem on putting my bike back together
    President:
  • 1,138 Answers
Try here for pictures and instructions:http://www.parktool.com/repair/readhowto.asp?id=64 Don't forget to check out the other instructions under this heading such as: rear derailleur overhaul.
Posted on Sep 11, 2009
Way. Won't my e bike Chang to second gear
You need to replace the switch...the logic board will not allow speed change because its sees speed switch at same position all the time when ignition switched off then on
Jun 04, 2015 | Motorcycles
Why does my 2007 1100 V-star die when I put it in gear?
Hi Don does the bike jump forward as of the clutch wasn't working? If so the clutch is stuck. To fix put thd bike in high gear and hold in the clutch push the bike back and forward with the help of a friend until it frees up. If this is not the problem check the side stand switch it might be faulty. If you have a doubt about the switch join the two wires together temporary to test. Regards Jim...
May 10, 2015 | 2007 Yamaha V Star 1100 Classic
When i put my 1987 Yamaha Virago in gear, it dies
Yamaha motorcycles of this vintage often have issues with their kickstand switch. This switch can be disabled by clipping the two wires that go into the switch and wiring them together--the kickstand switch is normally closed (letting current flow) when the stand is up; the switch is open when the kickstand is down.
This is more afield than your electrical concerns, but if the clutch plates have bonded together, the bike will stall when you put the bike into gear. The bike will start and idle fine, but basically, you don't have a working clutch, so the bike will stall out when you dump it into gear while at a standstill. You can test for this by starting the bike and having someone push the bike to get up to a little speed, then trying to shift into 2nd gear. If the bike lurches forward before stalling or keeps running, you have a clutch, not an electrical issue.
Folks sometimes get lucky, and working the clutch plates a few times will free up the sticking plates. I have had this problem with a mid-1970s vintage Honda that I don't ride very often. Eventually, the clutch plates free up and the bike is good to ride again.
Mar 09, 2012 | 1988 Yamaha XV 535 Virago DX
When i try to change to firsr gear it shuts off
You are either leaving your side stand down while putting the motorcycle in gear and the side stand safety switch is turning the bike off (It is designed to do this.). Raise your side stand before putting the motorcycle in gear.
Or, the side stand safety switch is defective and needs to be replaced.
Mar 29, 2011 | 2003 Suzuki LS 650 Savage
Bike cuts out when i put it in gear,,,,,,,,,,,,1990 xt 600
Might be a problem with your side stand switch, if the bike thinks the stand is down then every time you put it into gear it's going to cut out. Try manually operating the switch. You can also disconnect the side stand switch and connect the wires on the loom side directly together in case the switch itself is faulty and can't close the circuit to allow starting.
Feb 21, 2011 | 1990 Yamaha XT 600 E
Bike runs in neutral but cuts out when a gear is selected.
Your sidestand switch kills the engine if the bike is put in gear with the sidestand down. If your stand is up and this is happening either the switch is broken or out of position. If it is broken you can twist the wires together until you can replace the switch. If it is just bent out of position you can bend it back carefully.
Apr 15, 2009 | 2001 Suzuki GSX-R 600
Honda Shadow 600 c won't start in gear after battery change
The kickstand switch is either bad or bent out of position. See if you can activate the switch manually. Does the bike run now? If so, the switch is bent out of position. If it still won't run, jumper the wires together until you can replace the switch.
Apr 11, 2009 | 2002 Honda VT 1100 C3 Shadow Aero
Lack of power and low revs
Remove and clean the carbs. Remove and clean the fuel petcock water trap then put everything back together. Try the bike now.
If still bad then take it to the shop and ask for a compression check. You may have some burned valves.
Mar 16, 2009 | 2004 Suzuki VL 125 Intruder LC
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
