Question about Microsoft Xbox 360 Console
My CD Has A Scratch Shaped Like A Circle - Microsoft Xbox 360 Console
  • 47 Answers
Its where the xbox has been knocked over with a game in it
Posted on Sep 10, 2009
Scratched screen
now this works sometimes. use t-cut as you would for a car make sure the tv is cold and rub it in slowly going round in a circle across the scratch. DONT push hard onto the screen. clean off when it is dry. then use some lcd screen cleaner and the scratches should not be noticable now.
Oct 02, 2013 | Hitachi L46S603 TV
Any suggestions for a shape sorter toy that is not the usual toy of putting boring plastic shapes into the box?
You can try these Noah's Ark shape sorters available on Amazon that are shaped like animals.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=shape+sorter+for+kids+noah%27s+ark&rh=i%3Aaps%2Ck%3Ashape+sorter+for+kids+noah%27s+ark
or this clock shaped sorter: http://www.amazon.com/Melissa-Doug-Wooden-Shape-Sorting/dp/B000GKATU0/ref=sr_1_1?ie=UTF8&qid=1361430533&sr=8-1&keywords=shape+sorter+for+kids
Definitely not your run-of-the-mill circle in the circle hole shape sorter. Hope I helped!
Feb 03, 2013 | Toys
My gta 3 dosnt have a scratch on it and it freezes when its almost done loading can you help
Well, if its just that game, look closer. you may have a circle scratch. If you have an xbox 360, and it happens with ALL your games, then you may be close to getting the red ring.
May 20, 2011 | Video Game Consoles & Games
How to repair opc drum on canon ir400 without change it
if there is minor scratch on the drum surface, cover it with solvent based glass colour let it dry and re install the drum. if there is scratch on the sides of the drum full circle then cover it with selophane adhesive tape, make sure to wind the tape in counterclockwise and one turn only.
Oct 06, 2010 | Canon Office Equipment & Supplies
How do people fix scratched game disk"s
http://cgi.ebay.co.uk/CD-DVD-PS2-XBOX-DISC-CLEANER-SCRATCH-REPAIR-KIT-P65_W0QQitemZ260455729179QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item3ca45f081b#ht_2688wt_939
This is the type of thing you should use, they really do work and you can get them world wide form all ebay sites and shops.
You can also try a home method, this is to use a cloth and toothpaste, toothpaste will act like fine sandpaper and small circle rubbing over the area will buff the scratch out.
Jan 02, 2010 | Microsoft Xbox Console
Circle shaped light blinks shortly after start
look in owner manual to see what light is. may be brakes abs or check engine light. If CEL, you need computer test for fault codes or you will ruin $1000 converter.
Dec 12, 2009 | 1990 Mercedes-Benz E-Class
Xbox 360 console
Now here's what i think... Your game cd most probably has a scratch on it at the part where the simming program is stored...First just look at your cd in good light from various angles if there is a scratch. If there's a deep/moderate single scratch (just a line) or even a light circular scratch (an entire circle is traced around the disc) then this is most probably the source of your problem. SOLUTION 1 : If either of the two i said do exist then you'll have to get your cd cover removed. thats a comlicated process and very few people actually do it. Based on where you stay i could help you out. SOLUTION 2 : Now this would seem the better option easily. Currently fifa 08 costs like $10-$12 on ebay. My sincere advice is just buy a new one. I've used US dollars here coz I don know where you're from but im pretty sure once you've converted it to ur local currency it'll be roughly the same. SOLUTION 3: And finally i'm pretty sure you would have tried this. Dust your cd very carefully (from the centre to the end each time and not going in a circle) , plug it in and then pray. This has a 5% chance of working but won't hurt to give it a try right? Hope this helped.
Aug 26, 2009 | EA Sports FIFA Soccer 08 for Xbox 360
Scratch works only on pause
The problem is with the tiny button that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Sep 01, 2008 | Vestax CDX-05 Turntable
Vestax cdx-05s
The problem is with the tiny grey switch that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Jun 24, 2008 | Vestax CDX-05 Turntable
Microsoft Xbox 360 Console Logo
93 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
