Question about Argus Cameras
Battery cover will not close when batteries are
Battery corer will not close when batteries are installed - haven't been able to use this camera but once
    President:
  • 1,187 Answers
The cover will close.
First, remove the batteries and try to close the latch.
Please "add comment" to let us know that it can close without batteries.
If it cannot close and latch, then the cover is broken.... can't fix here.
If you can close and latch it w/o batteries, then:
If you are using rechargeable batteries, they might be slightly bigger than alkaline batteries.
Put one alkaline battery in the camera and try to close and latch it. You may now know the "tricky" maneuver you have to do in order to close it with the batteries installed. Now try two batteries, etc. until you can maneuver all batteries.
I think this will work for you.
Posted on Sep 10, 2009
Olympus tg 620 does not power on
When a camera does not want to power on. the best thing to do is remover the battery, charge the battery and chaco all contacts on the battery, and in the camera. All contacts should be clean and shiny. You can clean contacts only with a dry clothe. Never use anything sharp in or close to a camera. When you reinsert the battery, check is the battery door / cover closes correct. Most cameras do have a switch to chaco if the battery door / cover is closed.
Feb 02, 2014 | Cameras
Sony Cybershot DSC-S600 won't stay on
Have you tryed rechargeable batterys on the camera, generally they are higher quality and should work better.
Jun 20, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Camera won't turn on
If none of the suggested causes helps resolve the issue, then I suggest you bring it in for repair.
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
May 03, 2012 | Kodak EasyShare C330 Digital Camera
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
Lens cover would not close. Now camera will not turn on.
Lens cover not close, This will happens due to two reasons.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Rating the solution is highly appricaited...Good Luck.
Mar 03, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My Sony cyber-shot DSC-S500 the cover for the battery compartment will not close completely...and even when I hold it closed the camera fails to come on every time
This problem can be caused by the batteries installed incorrectly. The battery closest to the outside edge of the camera should have the "+" button down and the inside battery should have the "+" button up.
Aug 19, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Canon 40d won't turn on, LCD is blank.
There are several different things that can cause the camera to not start up. Refer to your user manual to check each of these items. If you don't have your user manual, you can download it here.
1) The battery is not properly installed in the camera. (p.26)
2) Make sure the battery compartment cover is closed. (p.26)
3) Make sure the CF card slot cover is closed. (p.28)
In addition, the battery may not have been properly recharged. Double check that the charger is plugged into a working outlet, and double check that it shows that the battery is fully charged.
If none of these fix the problem then you have a defective camera - one of the switches for the battery compartment or the CF card slot cover may be not properly indicating that the door is closed. If that's the case, you need to either return it to the place of purchase as defective, or send it in to Canon for warranty repair.
Dec 26, 2008 | Canon EOS 40D Digital Camera
Camera
Courtesy: http://photography-on-the.net/forum/showthread.php?t=151603
Jul 20, 2008 | Olympus FE-210 Digital Camera
Kodak easyshare z730
May 19, 2008 | Cameras
Cameras Logo
430 people viewed this question
Top Argus Cameras Experts
Raj Patel
Computer Links
Are you an Argus Camera Expert? Answer questions, earn points and help others
