Question about 474L TX 4-Button Replacement TX Remote
Remote failure Remote is no longer working. We have tried replacing the battery, checked fuses and still no luck.
  • 43 Answers
Check your metal connection that you slide your battery in between upon changing it. I had the same problem in which my car issued a warning "FOB". And what had happened was one of my connections fell off my circuit board. So if you have a steady hand and a solder gun, it may fix your problem.
Posted on Sep 10, 2009
Why wont my remote respond on a camry 2.2si 1997model. replaced batterys as well
ok try to keep it simple, maybe check your relay module. Which should be located under the hood, in the fuse & relay department. Also u might check the fuse under your dash if this does not work. If u have a owners manuel it should tell u what fuse/ or relay would need to check & the 1 u would need. if u do not have a owners manuel u could go to A O'reillys / Advanced Auto & they should be able to tell u the the correct fuse & or Relay u should check & or purchase. Hope I helped
Apr 30, 2014 | 1997 Toyota Camry
Remote will not longer work
You may have to reset the remote after removing the battery.
Some models you lock and unlock the drivers door with the key.
Check your owners manual if you have one.
Jul 23, 2012 | 1997 Mercury Grand Marquis
Our Air Purifier stopped functioning and no longer turns on. We tried with different electrical plugs and that does not work either. Basilio Rodriguez 1001 E. Clark St. Warsaw, IN...
1) Make sure the plug in the back is inserted firmly.
2) The little switch by the plug should have the "I" end depressed and the "0" end up.
3) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
4) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote.
5) Remove the plug in back, and pull out the fuse to see if it is blown. If so, replace it with the EXACT same size fuse, available at an auto parts store.
Jan 15, 2011 | Ecoquest Breeze AT Living Air Purifier
2000 vw jetta Remote key no longer works, electric...
try the 10a fuse for the light inside,the symbol on the fuse panel is a light with a line on the top, it controls alarm and windows too
May 21, 2010 | 2002 Volkswagen Jetta TDI
My apex digital converter's remote no longer works. Therefore I have no TV picture because the apex wants to be re-installed due to loss of electricity temporarily.
Remotes are pretty simple things to fix. a few problems, tests and fixes.
1) test remote closer to device - if it works then replace batteries.
2) If some buttons fail to work that used to work - disassemble and clean muck off board and rubber contact pad.
3) remote will not work at all at any distance - use camera on phone to see IR led operation when pushing buttons on remote - could be batteries, IR led failure or ceramic resonator failure - you need test equipment to faultfind.
The only parts that tend to fail on a remote are batteries, IR LED, Ceramic resonator, and dirty/wet board/rubber contact pads
Mar 19, 2010 | Televison & Video
Remote car starter no longer works. i replaced the battery in the hand held, yet still no response.
under the dash remove the main fuse or fuses from the main module for 2 min then replace and reprogram your remote
Mar 18, 2010 | Remote Start System
Car remote lock/unlock no longer working
Check the batteries in your remote the may need replaced and if working OK check to see if you power locks work pushing the door switch. (If batteries are low they may not disengage both the alarm and the locks)
Jul 08, 2009 | 1987 Toyota Supra
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
Amana Portable A/C Model#AP077R Remote control worked twice and then stopped working. Replaced batteries twice but no luck. Any suggestions?
I have a similar problem. The remote works for 5 to 10 minutes then no longer works. If I take the batteries out of the remote for 10 minutes (or longer) and reinstall them, the remote will again work for 5 to 10 minutes. I got a replacement remote from Frys and it behaved the same way.
Jul 06, 2008 | Heating & Cooling
474L TX 4-Button Replacement TX Remote Logo
430 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
