Question about Whirlpool Duet GHW9150P Front Load Washer
Front load whirl pool - broken tub front
It seems that after 8 years of this unit, the plastic "tub front" is broken. I wonder how that could happen. It looks like teh plastic is chewed up and now it rotates off the axis. seems like the shock is gone as well?
looking for a solution
  • 5,911 Answers
From your description, what it sounds like is one of the drum supports has broken on the back of the spin basket (inner steel basket) and chewed up the outer wash tub shell. The outside perimeter of the spin basket is rough like a cheese grater and will cause significant damage if used after one of the drum supports breaks. The spin basket is not supposed to come in contact with the outer tub shell. I have seen this problem several times and it will require (at a minimum) the front tub shell, tub gasket and inner spin basket to correct the problem. The estimated costs could be:
Front Tub Shell - $221
Spin Basket - $146
Tub Gasket - $9
If my math skills are correct, that's $376 in parts. Depending on the damage, you may end up having to replace the Rear Tub shell as well, which would add another $242 on to the cost. That's a total of about $618.
All these prices are before any shipping costs and only if you wish to pursue the repair yourself. Most appliance repair companies will add over $300 in labor alone.
I do have instructions on how to replace the spin basket, but it is labor intensive.
You need to ask yourself if this is worth the $600 in parts to repair, or would it be wise to purchase a new one. I wish I had better news for you.
To dispell any rumors or myths, this problem is know in the field. It is not common, but it does happen. Some of the welds on the back of the spin basket have been known to break causing the tub to spin off balance. This is not something that the average consumer will cause to happen, unless you consistently overload the washer. I do not know of any recourse you have at this point because the appliance is 8 years old.
If you wish to pursue this repair, please let me know. I hope I have been of some help even though it may not be pleasant news to hear.
Posted on Sep 10, 2009
Testimonial: "THanks for the the detailed email. It is very useful.I think Im in for a big $. Maybe need to replace the washer. THank you very much. "
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have the zuma whirl pool tub. the jets go on
This is an automatic feature to dry out the pipes and prevent mold. The next time you turn on the pump after leaving these tubs for a few weeks you get lots of black **** in the water and this is what this feature prevents. Sounds like the tub is working fine :)
May 23, 2010 | NRS Zuma Tub Only - R7236T - Standard
The drum seems to have become detached from the inside and has been scrapping against some plastic
The support bracket on your inner tub has probably broken. It involves replacement of the inner tub (drum) and probably the outer tub depending on the extent of the scraping. The parts will have a 5 year warranty, but the labor/service charge is your responsibility. Labor can be a bit pricey because of the extensive labor involved.
Feb 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the...
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Jan 08, 2009 | Washing Machines
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
F1 code
well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
174 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
