Question about Euro-Pro Shark 60 - 384
ITS LOCKED UP - Euro-Pro Shark 60 - 384
  • 14 Answers
Try to turn your handwheel using slight pressure. If it moves a tiny bit, you probably have thread caught.in between the bobbin wheel that holds your bobbin case. There is an outer ring and an inner shuttle. Place a drop of sewing machine oil in the inside of where these two are seated together. Now watch your shuttle as you turn the handwheel towards you. You may have to apply some force but you will not damage anything by using the force you can generate with your hand. You will see the thread move out. Pull it out with your fingers. If it breaks or doesn't get all of the thread, repeat the process. On most machines you never want to turn the handwheel away from you. This will cause damage to the motor over time. Make sure to stitch it out in straight stitch to check that it's sewing correctly. Thread jams happen when you get nesting (knots of thread) under the needle plate. This occurs usually when you are sewing light or tightly woven fabric with a heavy stitch, such as an appliique stitch. Try using a light wash-away stabilizer under the fabric or in the seam to prevent this. If it's an older machine or a newer Singer, hold the end of your top thread for the first couple of stitches, too.
Posted on Sep 10, 2009
LOCKED UP
My Pfaff 332 trips out when plugged into mains
Dec 24, 2013 | PfaFF Sewing Machines
My Singer Futura SES 2000 wheel is locked up and ERROR E4 (Safty Device Activated) HELP !!!
This happened to me once. I know it happens for different reasons. My problem was a thread 'locked' under the bobbin carriage. I opened the machine underneath, where is only one screw and found the thread locked between two wheels. If this is not your case, maybe inside the upper case? Also try to change the needle, and make sure there is not other strange object inside the hoop arm, or the bobbin cage.
Nov 13, 2013 | Sewing Machines
Juki locked
hi thereis your machine automatic thread trimmer or manual?
if automatic machine maybe movable knife is locked or there's some thread in between.
if manual maybe hook finger ( stopper ) is have thread or there's thread inside hook and need to clean. also same at automatic.
second. maybe needle bar is locked please try to loose the screw for needle par and check machine manually move or still locked.
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
Dec 31, 2012 | Juki DDL-8700
Toyota 8001 has locked/jammed
since the machine has locked up & jammed the machine needs to be serviced, to see if a part is damaged & to see if the machine is out of time
Apr 14, 2012 | Toyota Sewing Machines
H class locked up
thank you
your question will be removed
Mar 16, 2012 | Husqvarna Sewing Machines
Flywheel is locked
the machine need to be check by a sewing machine repair shop to find out why the flywheel is locked
Jan 20, 2012 | Bernina Virtuosa 160
The forward motion seems to be locked it will not go through its cycle
Do you mean that it is jammed? If, so find the thread or cloth that has locked it up.
Oct 20, 2010 | Singer 3116 Simple
Flywheel locked up on Babylock Ellegante. No threads tangled up anywhere.
When you removed and replaced the throat plate, bobbin and bobbin case to clean the shuttle and surrounding area, did you have the needle at it's highest position?
If the bobbin case is not properly re-installed, the hand wheel is affected.
If all of the above has been done and the handwheel is still locked up, the machine will need to go into the shop for service.
This is an expensive, computorized machine and any additional hands-on troubleshooting could add up to a costly repair fee.
May 16, 2010 | Sewing Machines
Singer Merritt 8834-My bobbin Wheel is Locked :'(
pull it towards you. if this does not work take off the rubber but usually you put finger underneath and pull. or catch on side of bobbin winder. hope this helps try oiling it as well. the spring or hing bit.
Mar 26, 2009 | Singer 7462 Mechanical Sewing Machine
Serger locked.
Unfortunately my experience has been whenever a serger gets "locked up" or "frozen" it requires a trip to the service department or getting a new machine. Best bet call your repairman and tell him what the problem is. You won't be able to fix it yourself.
Jan 27, 2009 | Brother 925D Serger
Euro-Pro Shark 60 - 384 Logo
267 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
