Question about Panasonic DMR-ES30 DVD Recorder/VCR
DVD stuck in panasonic DVD recorder
DVD will not eject U 99 shows in window Switching off and on has not helped Any ideas please?
  • t28owken Feb 06, 2009
    put a disc in dmr-es30veb display reads self check, but will not let me have the disc back
I just had the same problem today. Put a dvd in and then it would not open. I found a couple of answers and did not work. I am at a business so I figured we would just replace it. Opened it up
and removed 8 screws and 2 plugs. Put a small screwdriver under the round metal piece on the top and lifted it up carefully. Used a par of needle nose pliers to pull the dvd out (carefully). Put it back
together and it is now working.
I saw answers from the hard drive is bad to it is not something that can be fixed.
Thanks
Posted on Oct 13, 2008
DVD stuck in my Panasonic DMR-E30
Hi Rock.
I had the same problem like this on my machine. The best way to fix it is to turn the machine off completely and hold on the eject button then turn the power on. You want the first thing the player does is to eject the disk without trying to read it first.
I hope it works let me know if it doesn't and i'll try and recreate the problem on my player and see what i can do to get the disk out.
The last resort is to manually take the disk out but lets cross that bridge if my suggestion above doesn't work.
Thanks
smeags.
Feb 18, 2008 | Panasonic DMR-E30 DVD Recorder
I hadnt used my machine in a while. I went to transfer from a VHS to DVD Loaded both - no problem After finishing the transfer the I couldnt get the DVD to eject Help please
Did you follow directions on how to transfer VHS to DVD ? When the dvd is finished copying it MUST!! finalize the copy. If you attempt to eject DVD while in FINALIZING it gets stuck. Try and unplug the power for about 1/2 hour. plug in and eject. p.s. read the manual....the machine is complicated!!
Aug 11, 2011 | Panasonic DMR-EZ48 DVD Recorder
Panasonic dmr-ez47v won't recover from u61 code faul. Unit keeps ejecting tray and switching off.
no solution sorry, I have same problem. any one else with same prob?. Thought panasonic was a good make, 18 months old and now knackered.
Dec 01, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
VCR, DVD PLAYER
Try resetting the unit. Push and hold the on/off button for 10+ seconds. --or-- Look for a reset button behind the drop down door, and gently depress it with a pen point for a couple of seconds. If this does not work, try calling Panasonic.
Apr 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hung up - disk won't eject
cd recorder disk will not eject
Dec 08, 2007 | Panasonic VDR-M70 DVD Camcorder
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-ES30 DVD Recorder/VCR Logo
178 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
