Question about Sony STR-DH500 A/V Receiver
Help with setting up additional sets of speakers to a receiver.
I bought a Sony surround sound receiver. I will set up the surround sound in the Family room, question is how do I hook up the speakers that are pre-wired in the other areas in the house? Do I get one of those boxes that allows you to hook up additional sets of speakers? I think they come in 4 set configuration and 6 set configuration? Any recommendations on what brand to use? Best Buy sells them for $129, internet sells for around 30 dollars.
SOURCE: No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Posted on Feb 10, 2009
welcomejee
  • 10594 Answers
SOURCE: I bought a Sony STR-DE585 5.1 Receiver about 6
Click Sony Support and download copy of Instruction Manual of your receiver. Hope this will help you to set it up.
Posted on Mar 16, 2009
mlapres
  • 757 Answers
SOURCE: Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Posted on Jun 18, 2009
  • 23 Answers
SOURCE: Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Posted on Jul 17, 2009
Nomodo4u
  • 863 Answers
SOURCE: Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
Posted on Nov 01, 2009
Have no sound on my surround sound sony
Could be a number of things try each and test!
  1. Make sure the MUTE function has not been activated.
  2. Try turning up the volume level.
  3. Check that there are no headphones connected.
  4. Try setting the Audio/Video (A/V) receiver to a different Surround Sound mode. IMPORTANT: Verify that the source you are playing is encoded with Surround Sound audio. If not, the audio will be very difficult to hear using a Surround Sound setting. Set Surround Sound to OFF when playing a source that is not encoded with a Surround Sound signal.
  5. Check each speaker to make sure they are properly connected to the A/V receiver.
  6. Perform a Test Tone function to verify if the speakers are working correctly.
  7. Verify all external audio sources are securely connected to the appropriate inputs on the A/V receiver. NOTE: If the audio is being sent from a television to the A/V receiver, then it may be necessary to disable the internal speakers of the TV or set the audio output of the TV to FIXED or VARIABLE. If the audio output of the TV is set to VARIABLE, then you will need to increase the volume level of the TV.
  8. Make sure the correct audio input is selected on the A/V receiver.
  9. Confirm what type of HDMI devices are connected to the A/V receiver and then check the following:
    1. Test each one of the HDMI inputs on the A/V receiver to confirm that all of the inputs for the A/V receiver are working.
    2. Try a couple of different HDMI cables to verify there is not a bad set of cables.
    3. Unplug the video source from the A/V receiver and connect the source directly to the television. If there is still a problem with the audio, continue to the next step. If connecting the source to the TV corrects the sound issue, service will be needed on the A/V receiver.
  10. Verify the DEMO (demonstration) mode is not active.
  11. Change the ATT (attenuate) setting. NOTE: The procedure to change the ATT feature varies by model.
  12. Reset the A/V receiver back to factory specifications.
Dec 21, 2014 | Sony Audio Players & Recorders
I have a sony str-de 998 receiver,and there is no sound coming from the surround speakers. i have tried resetting ,but it doesn't help.any suggestions?
Your Sony receiver may have to be configured to use the surround speakers. This is accomplished as part of the set up process.
Sep 06, 2014 | Sony Audio Players & Recorders
Sony STR 1200 audio-visual sync
Yes it can be fixed.
Enter the speaker setup menu and toggle till you get to the selection for speaker distance. Assuming that you have your speakers properly positioned for correct reproduction of 5.1 surround sound, decreasing the setting for speaker distance will help. Start with 3-4 feet closer from the current setting. This enables the on board DSP (digital signal processor) to delay in milliseconds, the sound output for closer distance settings. It can also advance in milliseconds as well for further distance settings FYI.
Mar 24, 2010 | Sony STR-DA1000ES Receiver
When on 5.1 dvd ther is no sound from rear speakers,but i can run the test tone ok
check to see that the dvd player sound setting is set to BITSTREAM and not pcm. pcm is only 2 channel. Then check to see that the volume setting for the rear speakers in dvd is up, most sony receivers hold different settings for different applications, (vid 1, sat/tv, dvd) and remember when you switch between them. Rear surround should be up all the way , I believe for your receiver that is +10 also make sure you enable the rear speakers in the setup menu for surround sound.
Nov 28, 2009 | Sony STR-DE525
How to switch on Sub?
surround and subwoofer may not work if there is an additional graphic equaliser operating.
1. check in your receiver speaker setting ensure your speaker setup doesn not have subwoofer set to NONE. this will block any signal to your subwoofer socket.
2 when you select your surround sound setting setup, ensure you select the speaker mode you want, if there is a multicontrol knob, cycle through the choices
select subwoofer mode and set it to yes.
if you have set-up small speakers S in your speaker settings then it could be that subwoofer is set to yes automatically if you have large speakers L, subwoofer has to be set additionally in the subwoofer setting.
3 test subwoofer on alternative device to test it is working ok
consult manual on enjoying surround sound and adjusting the speaker settings.
Nov 16, 2009 | Sherwood R-945 Receiver
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Sony STR-DH500 A/V Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
