Question about Freezers
Freezer section switch's on and off every two minutes
    Problem Solver:
  • 5 Answers
The relay board is trying to turn on. You probably needs a new relay board.
Posted on Sep 11, 2009
Testimonial: "Many thanks, l'll try that"
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Frezzer is only 2 yrs old and already has defrosted on its own what seems to cause that?
This machine has an automatic defrost cycle that comes on automatically 4 times a day. During defrost the compressor goes off and the heaters inside come on and melt the frost from the coils. In about 20 minutes heat shuts off and compressor comes back on and freezes againl
Oct 18, 2010 | Continental Freezer Freezer display one...
Model fis -1d s7 pt victory freezer coil freezing up with-in minutes on start up defrost heaters and timer both operating
this is usually an indication that there is a possible problem with air flow. Look to be sure that the evap fan is running and in the proper direction. If all checks out, look to the expansion device. In most units with TXV's, replacement usually resolves the issue.
Sep 01, 2010 | Victory Freezer Freezer Roll Thru two...
Frosting up in the freezer and not cooling in the food compartment kenmore 363.9557852
It sounds like you have a defrost problem.
All the cooling for both sections takes place in the freezer behind the back wall. A fan back there distributes the cold air throughout the freezer and fresh food section. Every 8 - 10 hours a heater comes on for about 20 minutes to eliminate the frost from the evaporator coils back there. If this defrost cycle fails the frost will build up to a point of no air flow so the fresh food side and most of the freezer start to warm up.
The best way to take care of this is to turn it off and unload the freezer, take the shelves out and the screws holding the back panel inside the freezer out. Remove the back panel from the freezer. Use hot water and a hair dryer to unthaw the ice and frost, you will need lots of towels as the melting will bring lots of water on to the floor. Once the frost is gone you will need to install this part WR51X443. The picture below shows it. The kit contains new heaters and thermostat.
Apr 26, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Evaporator coil in freezer red hot and water dripping on it.
This normal operation. Happens twice a day to defrost the freezer coils. Last about 20 minutes.
May 02, 2009 | Kenmore Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Hotpoint Mistral frost free fridge freezer.
This is a little hard for me to understand being a yank and all. 0C is 32 Fahrenheit, right so 4/5 is about 40? make sure everything is working, compressor , evaporator fan motor (the one inside) condenser fan motor (the one outside) if you have one. You should have an adjustment for freezer and one for the fridge sections, right. The fridge section controls what amount of cold air comes from the freezer compartment. Check the vents inside, make sure they are not blocked and they open and close when you adjust the control. If this all checks good then check the thermostat. If the compressor shuts off prematurely, then a new thermostat may be in order. If you think you can do this, find the thermostat, by-pass the wires. this will make the compressor run continuously. After 20 minutes or so it should make the desired temperature or close to it. None of the fans or compressor should turn off while this is by-passed.
Dec 31, 2007 | Freezers
Freezers Logo
54 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
