Question about Kodak Easyshare C813 Digital Camera
Kodak easy share C813, the display is over saturated
On the kodak easy share C813, the display is over saturated and just appears as very bright. The pictures when viewed on a PC are fine, its just hard to take pictures when the brightness is so high! Anyone know how to rectify this if there is a setting (cant seem to see anything in the menu).
    President:
  • 1,188 Answers
Using exposure compensation to adjust picture brightness Before you take a picture, you can adjust exposure compensation to make pictures darker or lighter.
The exposure compensation level is shown on the LCD; the LCD gets brighter or dimmer.
OR
You need to upgrade the firmware.
Download this file to your pc and follow the instructions:
Firmware Download
Installation Instructions IMPORTANT: Print this page before continuing.
Prepare your Camera CAUTION: Loss of power during the firmware upgrade can render your camera inoperable.
  1. Connect the optional KODAK AC Adapter, or install a new or fully charged battery in the camera.
  2. If you have pictures on the internal memory of your camera or on a memory card, save the pictures to your computer.
Download and Extract the Firmware File
  1. Download the file to your computer.
  2. Double-click the file to start the WinZip Self-Extractor.
  3. Select Unzip to folder, and specify a location, or leave the default location.
  4. Click Unzip. The firmware file unzips to the specified folder.
  5. Note the location of the folder. The file has a .fw file extension.
  6. Close the WinZip Self-Extractor.
Select a Method
  • If you do not have a memory card and card reader, use Method 1.
  • If you have a memory card and a card reader, use Method 1 or Method 2.
Method 1
  1. Visit the EASYSHARE Software Web page at www.kodak.com/go/easysharesw, and download the latest version of software.NOTE: EASYSHARE Software version 6.x or later must be used during this procedure.
  2. Remove the memory card from the camera.
  3. Turn on the camera.
  4. Format the internal memory of the camera:
    1. Press the menu button.
    2. Select Setup.
    3. Select Format.
    4. Select Internal Memory.
    5. Press OK.
    6. Press OK to continue.
  5. Connect the camera to your computer using a USB cable.NOTE:The first time you connect your camera to your computer, Sync andTransfer Setup or Sync and Transfer Assistant prompts appear on thescreen. Follow the prompts to set up the camera as a device in thesoftware.
  6. Start EASYSHARE Software.
  7. Select Tools > Sync and Transfer Manager.
  8. Select your device from the list in the left column, and then select the Info tab.
  9. Click Update Firmware, and go to the location where you downloaded the firmware file.
  10. Click Open to copy the file from your computer to the internal memory on the camera.
  11. Turn off the camera, and then disconnect the USB cable from the camera.
  12. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  13. Turn off the camera, and then turn it back on again.
Method 2
  1. Remove the files from the memory card.
  2. Place the memory card in the card reader.
  3. Open the drive corresponding to the memory card to view the card contents.
  4. Check that a System folder exists on the memory card. If not, create one.
  5. Locate the firmware file on your computer and copy it into the System folder on the memory card.
  6. Remove the memory card from the card reader, and insert the memory card into the camera.
  7. Turn off the camera.
  8. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes.
  9. Turn off the camera, and then turn it back on again.
Posted on Sep 10, 2009
I having problems with uploading my pictures from my kodak easy share c813 to my gateway disk top computer, when i hook up the usb cable I gat a blank page
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
Apr 10, 2011 | Kodak Easyshare C813 Digital Camera
How do I download pictures from my Kodak easy share c813 to my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 06, 2011 | Kodak Easyshare C813 Digital Camera
Need to install driver for mac for the kodak easy share digital camera
http://support.en.kodak.com/app/answers/detail/a_id/16433/kw/c813
You might want to consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use iPhoto or any other photo cataloging program.
Nov 30, 2010 | Kodak Easyshare C813 Digital Camera
I still cant upload pictures to the computer after trying the above solutions from kodak easy share c813. i have the latest up dates
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Oct 22, 2010 | Kodak Easyshare C813 Digital Camera
How to transfer pictures from internal memory to memory card (Kodak easy share C813)
E-mail your question to this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 09, 2010 | Kodak Easyshare C813 Digital Camera
How to convert videos from Kodak memory card to laptop?
I understand you?re interested in transferring the information from your camera to your computer. Please follow the following steps 1: Connect the camera to the computer using the USB cable, U-8. 2: Turn the camera on 3: A window will automatically appear on your display. Please follow the steps given to you by the programme. If no window appears: 3: Go into my documents 4: Find the location of the camera and your pictures 5 Drag and drop from the camera to the computer You need a video viewing software to view the videos. As an example you can download QuickTime Player from www.apple.com
When i turn my kodak easy share C813 on it says
take out the battery and set your mode dial to auto and put the battery back again and turn on your camera.
Aug 19, 2009 | Kodak EasyShare CD33 Digital Camera
How can you transferr pictures from the camera to the computer with a Kodak eastshare C813
i can't get my kodak easy share to transfer pictures or videos to my computer.
Feb 20, 2009 | Kodak Easyshare C813 Digital Camera
I can't use this thing
The kodak c813 is just plain defective,what's wrong with this company for putting out a camera that won't work,we need a class action
Jan 10, 2009 | Kodak Easyshare C813 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
255 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
