Question about Samsung WF337AA Front Load Washer
Fabric softener does not despense
THE DESPENSER FOR THE FABRIC SOFTNER IS NOT WORKING, WHAT IS THE FIX
  • Anonymous Mar 15, 2014
    softner dispenses when pored in
Clean the water filter in the back of washer. Look up inside of water inlets you will see water filters in cold and hot inlets. Pull stright out with a pair of pires and fush with water.
Posted on Jan 08, 2009
    President:
  • 1,294 Answers
Close the wall faucet, unscrew the hose to examine the screens; clean out, refit carefully. Open the valve to check for leaks. If the problem persists open up the top to check the pipes & dispenser drawer.
Posted on Jan 04, 2008
I had the same problem with mine, and just added water in with the softener to fill it 'to the line' - and it's worked since!  Can't hurt to try!!
Posted on Jan 20, 2008
Fabric softeneer despenser has water in it. We have not used the despenser. Have a whirlpool cabrio top loader
Had one where the softener dispenser had all kinds of dried up crud from the softener which caused the water to collect there instead of drain down. It actually looked like wax, after cleaning it out the water problem went away.
Apr 20, 2011 | Whirlpool GSC9455 Top Load Washer
The detergent dispenser want despense the fabric softner
Hello. This is a common problem due to the fact that fabric softener collects in the dispenser and gums it up. Begin with an empty washing machine. Add two cups of vinegar to the fabric softener dispenser and then run the machine on the maximum water and hottest water setting. Once the cycle is complete check it out. It will be as clean as a new machine. If this treatment didn't completely clean out the dispenser, repeat the cleaning a second time with two more cups of vinegar. regards, Joe
ps - kindly rate my answer as helpful. Thanks.
Feb 10, 2010 | Washing Machines
Fabric softener dispencer not working properly, we are getting softener stains on our clothes. at the end of the cycle, there is undiltued softener in the bottom of the drum.
I just had this problem with our 5 year old Atlantis. The key I found was to lift the fabric despenser off. Then you will need to clean it really well. It get builfd up of the Fabirc softner over time. You wil also need to clean the interior of the agitator which will be easy after you have the dispenser off. I used a flat head crew driver and light scraped all the "Gunk" off the inside of the agitator. Take your time and get it as clean as possible all the way down to the bolt that hold the agitiator on. After you are all clean run a hot water load and disefect with a bit of bleach in the dispenser. Put the agitator back on and it should be solved. You will be amazed and possibly grossed out at how much stuff you clean out of it.
Feb 09, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune Washer model # MAH9700AWW will no longer despense fabric softner,
yes the cup that the fabric softner goes into the cap of it is called the syphon. poor water in the cup and go over the max line does it syphon the water?
Jan 30, 2010 | Maytag Washing Machines
Hello sir,i have a kenmore series 90 washer & dryer.this specific machine has top dispensing detergent/bleach&softner.when it becomes time for the softner to be dispensed on the re-fill the machine...
PLease check the hose that goes from the INLET VALVE to the dispensing system cup on your washer. This hose probably has a hole or the plastic dispensor is cracked and therefore leaking.
The inlet valve is working and when the time comes the water goes to the dispensing cup, so the system is working it is just the hose, dispensing cup or both.
Nov 19, 2009 | Kenmore Washing Machines
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
GE Front Loader will not despense Fabric Softener
We checked the cold water line that goes into the washer, it had some pretty nasty stuff in it, and once we cleaned it out, and soaked it in CLR, it cleared up the line. Once we reattached it and ran a cycle, it went great. I am assuming with the line being clogged it didn't have enough water pressure to flush out the fabric softener.
Apr 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Machine will not use fabric softener
the despenser has a servo motor on the top of the despenser, you have to remove the top of the washer to get to it, it is on the left side of the unit looking form the forunt, check the motor woth a vom meert on resistance, if you get a reading, meter needle moving twards the right the motor probally is good, if no eter movement the the motor is bad
if you have meter movement after checking the motor then the control board is bad
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
may be the dialer is not working to that function
Dec 10, 2007 | Samsung WF337AA Front Load Washer
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Samsung WF337AA Front Load Washer Logo
1,074 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
