Can not remove front cover on emachine t26 - Computers & Internet
    Brigadier General:
  • 10,406 Answers
With one hand, grab underneath the bottom edge of the front.
With the other hand, hold the rest of the case motionless.
PULL! HARD! ... but do not pull more than 3 inches,
because some small wires connect the lamps on the front-panel
into the inside of the case, and you don't want to break those wires.
Works for my eMachine. :-)
Posted on Sep 10, 2009
  • 3,153 Answers
Some E-machines have some small screws just behind the front on the inside of the case that may need to be removed.
Most may just need a firm tab with the palm of the hand against the top front to start it on it way.
watch doing that on the sided as these cases can be sharp.
  • Project NOMAD
    Project NOMAD Sep 10, 2009
    ikkenom is also correct but do watch out three inches may be a little much for the fine cables in there.
    Dont yank it off or you will be in all sorts of problems !
Can not open the case on a emachine t1831
Remove ALL cords plugged into the computer. Lay the computer on it's side with indent facing up and remove two large thumb screws from back. Pull the side towards the back using the indent for leverage. If it is really stuck insert a small flat blade the in the slot between the front cover and side and CAREFULLY twist as you slide the blade from to bottom. The side needs to slide towards the back before it can be removed.
Jan 23, 2014 | Computers & Internet
Can't get the cover off
Ensure that all required screws have been removed. Make sure that you're removing the correct panel. Clear any cabling that make be hanging up your removal of the panel.
Nov 12, 2012 | eMachines T1440 PC Desktop
The fan keeps running on my emachine pc
to cure this increased fan speed and overheating issue, i strongly suggest you get a few cans of 3m or whatever brand duster cans are available to you. remove the side case cover with the system shut down and power supply unplugged and blow the dust off the fan blades and heat sink fins located behing the fan that covers the boards processor. some dust may be stubborn and can be remove with a gentle assistance from a tooth brush. be sure the air inlets at the front of your pc case a free and clear of blockages too. this should prevent your fans from running at such a high speed as needed to cool your system.
Jan 19, 2011 | E-Machines eMachines Desktop PC
Valvers are open and no kinks in the hose still have slow water flow
The first thing I would do is remove aererator from spout outlet. It should not be on very tight so you may be able to remove it by hand. If you are standing in front of faucet turn aereator clockwise or to your right to remove. If you cannot get it to turn wrap aereator with masking tape,duct tape or rag to keep from marring finish and use channel lock pliers or standard pliers to remove. There should be one or more brass or stainless steel screens and possibly a brass disc with a small hole in center. Also there should be a rubber washer that goes between faucet spout outlet and aereator. With all these removed , see if flow rate is improved. Carefully clean screens and disc. Reassemble in reverse order. Hope this helps.If this dosn't improve flow rate you may have to further disassemble vavle to find source of blockage. Thanks
Nov 11, 2010 | Price Pfister T26-4CBY Avalon 4 Hole...
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
Emachines t3612. trying to remove front cover to remove/install dvd burner. how does cover come off?
On alot of desk top computers you will need to remove both side panels to release the tabs for your frount cover.
Oct 31, 2009 | Computers & Internet
CD drive button broken
You might try to remove front cover from you CDROm and checked whether button is not broken or stucked
Oct 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
I have a c1641 emachines and removed the single sided piece and wanting to remove the entire cover and having problems getting it off. Also how do you remove the very front of the machine? Just one other...
With one hand, grab underneath the front of the front-piece.
PULL! HARD! ... but not more than 2 or 3 inches,
so that you do not break any wires from the lamps on the front
that run inside the case.
See: http://www.eMachines.com for your specific model.
Lots of information about "end-user-replaceable" parts.
Sep 10, 2009 | E-Machines (308714) Motherboard
How to disassemble emachine computer case?
Cover moves from front to back. the front plate should snap out from the bottom.
Aug 31, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
308 people viewed this question
David Payne
David Payne
