I have reset soft and reset hard--still the screen does not respond to the tapping! I have switched out batteries, recharged... what else can I do to get it to respond on the screen?
  • valeriejs Sep 10, 2009
    actually it is a pda from dell--axim 30 pocket pc; is your comment still valid?
    bother
  • 6,784 Answers
HI. Due to the failed resets you have mention, this will confirm that the touch screen has failed. this screen is incorporated and linked to a logic board. This board receives the signal of each control sector that is pressed and it also initiates the command selected as well.
This printer will require the professional hands of a skilled tech. the touch screen and integrated board should be replaced asap.
Service is recommended in this case...
Posted on Sep 10, 2009
  • Michael Masters
    Michael Masters Sep 10, 2009
    Absolutely. your PDA will use the exact components as well. it will have a touch screen that is linked, via ribbon cable, to a logic board. The solution i posted is valid.
  • Michael Masters
    This is a very common occurrence with most PDA's. The internal connections will break-off overtime(cold solder break). This will cause a no response issue when the touch screen is used. The service tech will normally replace the entire board.
I have a Dell axim x5 and it is stuck on a blue screen with the Dell logo. I have tried a maste reset like hold the power botton and the reset for 2 sec but after that i get a screen with the option clear...
Perform a Reset
Soft Reset
When you perform a soft reset, the device deletes any data that has not
been saved but saves any data that has been stored in memory. Try
performing a soft reset if the device does not respond when you tap the
display or press a button.
To perform a soft reset, use the stylus to press the reset button.
Hard Reset
NOTICE: When you perform a hard reset, you lose all the data stored on
your device.
Perform a hard reset if:
• You want to delete all the data stored on your device.
• You forget your password and need to clear it.
• Your device is experiencing severe operational problems and you have
already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you
perform a hard reset. See ActiveSync Help on your computer for more
information.
To perform a hard reset:
1 Press and hold the power button.
2 With the stylus, hold the reset button for about 2 seconds.
3 Follow the instructions on the screen.
Feb 12, 2011 | Computers & Internet
Tip
How To Soft Reset, Hard Reset, and Factory Reset Your LG Quantum
If you are uncomfortable with resetting your phone, or unsuccessful in fixing the problem, please contact the phone company for which you receive service from for help with resolving your issues.
Soft reset
To perform a soft reset, power the device off and back on.
  1. With the screen unlocked, press and hold the Power key to turn the phone off.
  2. When the phone is off, press the Power key to turn on the phone.
Hard reset
  1. To perform a hard reset, remove and re-insert the battery.
  2. Press the Power key to turn on the phone.
Master reset
IMPORTANT: The device will be set back to factory settings; all data stored on the device will be lost. The device may not be functional for up to 15 minutes after a master reset is performed.
  1. From the home screen, swipe left to expose your app list
  2. Tap Settings
  3. Scroll down and tap about
  4. Tap reset your phone
  5. Tap yes to confirm, then tap yes to confirm again
That's it! Your LG Quantum will now be wiped. It will then reboot and you'll be left with a factory fresh phone.
on Feb 10, 2011 | Cell Phones
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | Computers & Internet
Palm Zire 71
The top plastic digitizer is defective.
It needs to be replaced.
There are several sources on-line to buy such digitizer part.
Best regards,
Jul 14, 2008 | Palm Zire 71 Handheld
Palm m505 problem after hard reset
ouch... Try opening it up and run a business card between the digitizer and the screen. Fixes m500s and m100s.
Apr 02, 2008 | Palm m505 Handheld
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
HP Ipaq rz1710
Have u recharged it????
try to reboot it. there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Sep 16, 2007 | HP iPAQ RZ1710 Pocket PC
60 people viewed this question
k24674
jasbo
jasbo
