Funnel itself squeeze in on sides to release tabs. so many tabs broke a redesign was made 5-30-2005 , have to replace frame bracket and funnell. models after tant had new design. part number from exploded view: 3016JA2002C funnel 278d location number exp. view
3210JA0006S frame 278b location '"" '' ""
SOURCE: removal of broken funnel assembly and installation of new one
Same problem with mine. I guess I will try the screwdrive trick and hope I don't break the faceplate.
SOURCE: Ice and Water Dispenser Funnel
This diagram may help some.. should be a molding thats goes around outside of dispenser.. should be able to pop off and get at screws u need to get at...to remove and get at what u need too
http://www.partselect.com/Schematics/GE/00116598i01.gif
SOURCE: We have a LG LRSC 26923 frig. It will make and
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
SOURCE: water dispenser and ice maker stopped
If they both stopped working at the same time you probably have a blocked water line or bad water valve.
SOURCE: LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
