Question about Microsoft Windows XP Home Edition
How to remove white box from desktop - Microsoft Windows XP Home Edition
    Brigadier General:
  • 10,406 Answers
Right-mouse-click on the white box. Choose DELETE.
Or, right-mouse click on the white box, and choose PROPERTIES.
Then, click DESKTOP, and change the "wallpaper".
Posted on Sep 10, 2009
Stop one mac screen from becoming multiple screens
Mirroring displays the same image on each display.
  1. Make sure your additional display is properly connected and powered on.
  2. From the Apple (?) menu, choose System Preferences.
  3. From the View menu, choose Displays.
  4. Click the Arrangement tab.
  5. Enable (check) "Mirror Displays" in the bottom-left corner.
In the example below. the blue boxes represent each display that is connected. The white bar at the top of both boxes represents your menu bar and is shown on both displays when they are showing the same information.
When mirroring, your Mac attempts to match the closest resolution between the primary (or built-in) and secondary displays.
The usable resolution is the closest matching resolution for both the primary and secondary display. If you choose a resolution that is not supported on both displays, OS X reverts to using the closest matching resolution.
Extended desktop With extended desktop, your displays are treated as one, continuous desktop.
  1. Make sure each display is properly connected and powered on.
  5. Disable (uncheck) "Mirror Displays".
In the Displays pane of System Preferences, each blue box represents a display that is currently connected. The size of each box is relative to the current resolution of the display it represents. In the example pictured below, the larger box on the left represents an Apple 27" Thunderbolt Display, while the smaller box on the right is the built-in display of a 13" MacBook Air (Color LCD).
The white bar at the top of the left blue box represents the menu bar you see at the top of your display. Menu bar placement determines which display is treated as the primary display in OS X. To change your primary display, click and drag the white bar from one blue box to another.
You can also drag any of the blue boxes to change a display's represented location. Use this feature to make sure the connected displays match their real world location when navigating your desktop.
As shown below, each display retains its maximum resolution setting as they are operating as individual displays showing a continuous desktop.
lion_choose_max_resolution_.pngPress Command-F1 to toggle between video mirroring and extended desktop
Press Command-F2 to detect displays
May 01, 2014 | Apple 24" iMac Desktop
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
There is a white box ,which says BRIGHTNESS written in red color,at the center of the screen.How I can solve it?
Check your monitor buttons. Check for any buttons that adjusts the brightness. Press it and the white box should disappear.
Hope this works for you.
Jul 28, 2011 | Computers & Internet
Have an HP monitor and have a white rectangular shaped box that pops up in the center of the screen constantly, in the center of the box it says OSD Lockout. Can not get it to go away. What do I do?
To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked". Now if the problem continues, switch off the monitor and remove the power cable then let it sit for a couple of minutes to 5 and connect it again.
Sep 28, 2010 | Computers & Internet
My computer screen has a big white box over the desktop icons How can I fix it.please ?????
is the white square on the desktop or floating as a separate window? Can you use your PC and programmes OK, but it just looks rubbish?
If the latter I suspect that there is some sort of custom desktop which has been corrupted.
To change it right click anywhere on the desktop and choose properties. The choose desktop and swap the current one from anything on the list. Save and the background will change. If it is as I suspect the white square will also have vanished.
Sep 11, 2010 | Computers & Internet
Sequence of cross cable while connecting two computer
there r so many types of cross cables
this is Standard cross cable :-
white.orange ------ White green
orange ------ green
white.green ------ white.orange
blue ------ blue
white.blue ------ white blue
green ------ orange
white.brown ------ white brown
brown ------ brown
For more information please visit the below link
http://www.lanshack.com/make-cat5e.aspx
Please rate me if this solution works for you
Thanks......Have a great time
Jun 28, 2010 | Compaq Evo D510 Minitower (Open Box)...
Can somebody expalin how to upgrafe the memory from 512MB to 2048
open the box, inside you will see up to 4 longish rows where your memory slots are. On these slots are white levers these levers are used to fit and remove the memory module. Make sure that you have earthed yourself agianst the metalwork of your computer or maybe a radiator or anything meatl before you attempt to remove the memory. Press the levers and the modules pop up. then you place the new memory inline with both ends ofthe levers and push fit.... dead easy no problem at all. Hey Presto memory fitted .... amen to that.
Jan 05, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My computer is showing a floting box which say self test feature check, wit red,green blue and white box.What do this mean
its showing u monitor self test feature screen issue either with the monitor cable or monitor or the graphic card
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Have a pearl 8100 has a white screen with a dont signe in the center that has a circle triangle and square in the center of the ddont sign with the numbers 507 under it. i have downloaded the 8100 os to my...
1) Perform a clean uninstall of BlackBerry Desktop Software.
2) Download and install the latest version of BlackBerry Desktop Software from the wireless service provider's web site.
folow the trouble shooting steps:-
  1. Close BlackBerry® Desktop Manager, if it is running.
  2. Open the Control Panel and double-click Add or Remove Programs.
  3. Select BlackBerry Desktop Software and click Change/Remove.
  4. On the InstallShield® Wizard window, select the Remove option and click Next.
  5. On the Uninstall Options window, select the check box labeled Remove all user settings for BlackBerry Desktop Software.
  6. On the Confirm Uninstall window, click OK.
  7. On the InstallShield Wizard window, click Finish.
Oct 30, 2009 | RIM BlackBerry Pearl 8100
Old gateway desktop tries to start up but just shows white screen or menu
the last time my friend's old cp would not start and showed a white screen, it was nothing else than changing the power box that had gone dead from overheating - the fan was stuck hard since weeks!
Sep 06, 2008 | Gateway Computers & Internet
Microsoft Windows XP Home Edition Logo
638 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
