Question about General Electric A735 Digital Camera
I tried taking pictures and a message comes up on the screen "write protect". What is wrong?
    Brigadier General:
  • 11,967 Answers
That usually means the slide switch on the side of the card is in the locked position.
Posted on Sep 10, 2009
  • 4,806 Answers
To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this I tried taking pictures and a message comes up on - 59a6de4.jpg .
Regards.
SOURCE: I have a !LENS COVER message coming on the screen when I try to take a picture.
check out if there is a problem with the shutter...
Posted on May 29, 2009
  • 11967 Answers
SOURCE: MY a550 polaroid camera is saying card protected on the screen
When you take the card out, you are storing the pictures on the camera's extremely small internal memory. Is the slide switch on the side of the card in the unlocked position?
Posted on Sep 12, 2009
  • 102366 Answers
SOURCE: Fujifilem Z20fd I cant turn the card protection off which appears
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Is your flash working? Do you have the flash turned on?
Posted on Mar 16, 2010
  • 102366 Answers
SOURCE: memory card is write protected
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on May 25, 2010
  • 102366 Answers
SOURCE: sdcard protect: when I plugg on camera an error
Posted on Jun 17, 2011
When I try to take a picture an error message comes on the screen saying Write Protect
You neglected to specify the model of your Olympus camera so I'm assuming it's one of those that use SD/SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 29, 2012 | Olympus Cameras
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
May 25, 2011 | Intova CP8 Digital Camera
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Jun 27, 2010 | Olympus FE-190 Digital Camera
Write protect.
go to menu and find whether sttings is kept in protect pictures , set it to default and try again.
Feb 17, 2009 | Vivitar ViviCam 3750 Digital Camera
FUGIFILM FINEPIX Z10
Jan 30, 2009 | Fuji FinePix Z10fd Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Write protect written across screen,will not allow me to view or take pictures,why??
try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Sep 26, 2008 | Olympus Stylus 710 Digital Camera
How to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
May 18, 2008 | Microtek Take-it MV320 Digital Camera
Memory Card
Check to see if the lock tab has been put in the lock position. If yes then slide to the unlock position.
May 08, 2008 | Cameras
General Electric A735 Digital Camera Logo
134 people viewed this question
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
