Question about HP Photosmart C4180 All-In-One InkJet Printer
Hp photosmart c4189 all-in-one will not print!
Just codes and then non-stop chucking the paper out until I turn it off. It does it's own self test thing fine. I'm on a Mac, any help please?
  • ksapey Sep 10, 2009
    Help! a friend is desperate for a CV... cheers in advance
How do i fix a cartridge jam?
Hi andmary,
While using the HP Photosmart C4180, the printer may display error messages. These messages alert you, as the printer's user, to any problems affecting the printer's performance. The printer can display the message "Carriage Blocked" on the printer's display screen, stopping any current print jobs and preventing you from printing anything until you resolve the problem. The error message can be caused by an actual obstruction, such as a stuck piece of paper, keeping the cartridge carriage from moving freely inside the printer. Sometimes the error is a result of a software error.
Instructions:
1. Turn off the printer, wait 15 seconds, then turn it back on. Press the "Setup" button on the control panel, then use the arrows to highlight "Print Report" and press the "Ok" button to print a self-test page.
2. Remove all the loose paper from the printer's input tray. Turn off the printer and open the back door by depressing the tab on the left side.
3. Pull out any stuck paper, being sure to turn the rollers to check for small pieces of paper. Close the back door and open the printer's front door.
4. Remove any stuck paper from the printer. Move the cartridge carriage from the left to the right side of the machine, removing anything that stops the carriage's movement.
5. Push down on each cartridge, then pull each one out of its slot. Replace the cartridges in their slots, then push forward on them until they each click into place.
6. Plug the printer back in and turn it on, then unplug the printer's power cord from the back of the machine and the electrical outlet. After at least 15 seconds, plug the power cord back in and turn the printer back on. If the problem persists, take the printer to a repair shop.
Hope this helps.
Thank you for using Fixya!
Sep 24, 2011 | HP Photosmart C4280 Aio Printer
Carriage jam message...........comes on no matter what.........reset several times
Give a call to HP Tech support team they will try to resolve your issue. You can contact them (877-690-9305) Support For Hp Printer
Jun 21, 2011 | HP Photosmart C5280 Printer
HP Photosmart Printer 7850 I would like to print a self-test page because I want to know if the problems are with the printer or the applications I cannot install any windows software because there is only...
Here's how to print a self-test page.
HP Photosmart 7850 series printers
  1. Make sure plain paper is loaded in the In Tray and the printer is on.
  2. Press and hold the Select button.
  3. Press the Left arrow button once.
  4. Release the Select button.
Jan 04, 2011 | HP Photosmart 7850 InkJet Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
Photo,s from printer come out greenish,it,s a HP c7180 photosmart !! self test diagnostic shows white stripes in Magenta ?heads have been cleaned
Don't have a solution, but a similar problem and maybe a work around. My prints on glossy paper come out with a strong red tinge if glossy paper is specified. Seems to work all right if plain paper is specified with glossy paper in tray. Was on chat and email and phone support with HP for about two days. Went through all tests and resets with them. No solution from them except an offer of a refurbished Model 309 for $200. It was on sale at Costco for $169 that same day. I didn't buy it as it is missing features on the C7180.
Note the extended self test shows the light magenta ink is not printing - but it does use ink and the ink drop counter shows it is using ink.
Try specifying plain paper when you print on glossy. Maybe our problems are related?
Duane
May 17, 2010 | HP Photosmart C7180 All-In-One InkJet...
Paper jam warning. I cannot find any paper in
Please try to turn off your printer and unplug all the connection in the printer from its power down to its usb or parrallel connection. And let it up to 30 minutes to unplug and turn off. This process is letting your printer reset it self and loading its default and original settings. Usually it loads it original settings. After 30 minutes please plug all the connection of the printer and then turn the printer on and test the printer by printing a document or any files you want to print. Please observe what is the result.
Thanks
Aug 07, 2009 | HP Photosmart 8150 InkJet Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart C4180 All-In-One InkJet Printer Logo
171 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
