Question about Sharper Image Audio Players & Recorders
Sharper Image 3-CD model SA248 Doors opening problem
On my Sharper Image 3-CD player model SA248 the doors opening and closing mechanism does not work. When pressing the button it makes the right noise but the cogwheels do not move. How can it be repaired?
The bands that allow the cogwheels to turn, snap and needs to be replace.
Posted on Nov 27, 2010
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Sharper Image SA255 cd door would,not work, got frozen, not able to close it even manually
This could be due to a mechanical failure in the door mechanism, BUT I had a 3-disc unit on the bench recently and the control logic was messed up. Try the reset and check to see whether it specifies the drive you are having trouble with as the one to be loaded
Nov 25, 2012 | Sharper Image SA255 CD Shelf System
I have a Sharper Image Blue Night CD Player with a motorized CD cover that automatically slides up or down (to play CD) at the touch of a button. When I push the button to close the door (and play CD),...
I would first check to see if there is something that is obstructing the door, and if you cannot find anything, then you could take it to any electrical repair shop, and they could fix it for you.
Mar 26, 2011 | Audio Players & Recorders
Disc belt needed
You need only measure the diameter in MM and put that and "CD/Cassette drive belt" into google and you should find a supplier. A few MM either side shouldn't make difference. Drive belts etc are none specific makers by the way.
May 31, 2010 | Sharper Image SA265 Shelf System
The CD plays one or two songs and then stops and the sliding doors open
This indicates the CD player is having issues reading the disc. Here's my fix on dirty CD lenses:
CD just says loading
This can be as simple as a dirty CD lens. CAUTION!! The lens is delicate! I wipe CD lenses with ONE drop of glasses cleaner on a Q-tip and, starting in the center, wipe in circles to the outside. Do not press down! Do not force the lens side to side. It will move while cleaning but don't put more pressure than needed to move the lens 3/4 way down!
Its a cheap test to see if there is a fingerprint on the lens. (You won't be able to see it - does not take much)
If this does not help, it means it needs a laser or worse.
Apr 19, 2010 | Sharper Image Slim One-CD Stereo with...
Cd cover doesn't open
Fiddled with it, looked at hinges to figure direction should open and pulled it slowly open. Button doesn't work but I can open/close unit. Just flips up from the front edge, doens't slide back or anything.
May 13, 2009 | Sharper Image GM402 CD Shelf System
I have several NUMARK CDN88 dual cd players with door opening issues. One player set the doors open and close too fast and dislodges the discs. On the other I have to power the unit up and down several...
Going through this problem myself. I've diagnosed that the drive (motor) unit should separate from a magnetic disc that sandwiches the CD between it and the motor. For some reason the mechanism isn't powerful enough to pull it away when the drawer wants to open, so it sticks. It seems to be a mechanical, rather than and electronic issue. I'm looking at replacing both drives rather than a fix, for reliability issues. I've got a number of CDN models and it's only the CDN88 that has this issue !
Apr 29, 2009 | Nu Mark Numark Cdn36 Dual CD Player CD...
Light
You need the remote to turn that light off.
Jun 09, 2008 | Sharper Image Slim One-CD Stereo with...
575 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
