Question about Philips 42 in. Plasma TV
Coloured lines on screen
1" wide stripes 2 off going from top to bottom on the right hand side of the screen they are intermitent but becoming more frequent
    President:
  • 1,284 Answers
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Posted on Sep 10, 2009
Vertical 1cm white line,Dell Studio 1737
The LCD Screen is bad, replace it.
May 01, 2012 | Computers & Internet
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Feb 04, 2009 | IBM ThinkPad T21 Notebook
Vertical stripes on screen.
well, change ur screen their is failure in your screen line & row moudle
Sep 29, 2008 | Televison & Video
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
Yellow stripe down the screen.?
And a good evening to you!
It is possible that you have a bad LCD assembly, or possibly the LCD cable connector is loose. The only way to find out is to remove the LCD assembly from the top cover so that you can access the connector. It is located behind the LCD screen.
If you want a copy of a service manual for the disassembly process, let me know and I'll see what I can do for you.
Ron-
Dec 01, 2007 | Acer Aspire 1642WLMi Notebook
Philips  42 in. Plasma TV Logo
161 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
