Question about ASUS Computers & Internet
Asus M2N / Antec SP-350
I have an Antec SP-350 Power Supply with an Asus M2N MB & the Green LED light comes on on the MB but when I press the power button nothing happens. What could be Happening? ( this is the EXACT ASUS M2N MB: http://usa.asus.com/product.aspx?P_ID=74PPQIiEejvuIiHv ?
    Scholar:
  • 85 Answers
Things to try:
1. Check that the cpu fan is properly connected to the correct port marked CPU FAN.
2. Make sure the power cables are connected correctly to the motherboard.
3. Test the button switch with a multi-tester to make sure that it tests good.
4. Make sure the power switch is connected to the correct pins on the motherboard.
5. With the computer off pop the cr2032 battery out and pop it back in after a few minutes.
6. Test the power supply with either another motherboard or a power supply tester.
7. Test the motherboard with another power supply.
8. If all else fails replace the motherboard I have had a bad one from time to time even out of the box, and if you have a spare cpu you may want to test with that also. Cpu's hardly ever go bad I think I have had two go bad ever, not counting power surges and storm damage.
Posted on Sep 10, 2009
  • Eric Rotmil
    Eric Rotmil Apr 19, 2011
    Actually its a compatibilty issue , the antec psu won't work with asus MBs
Green led power light comes on then power goes off and comes back on repeatedly. It never posts.
Your motherboard was manufactured in late 2009. The green LED on the MB supplies DC power to the BIOS. This is known as standby. This is a relay is built into the MB maintaining the required 3 volt. When you power up the MB the power supply maintains the
3 volt DC to the BIOS. So the relay is not working. Suggest you contact Asus. All Asus MB's carry a three year warranty. Your board will need to be replaced by Asus. Call Asus at; 1-812-282-2787. (Asus Tech IL EST) M-F 8:00 to 5:00PM) There is a sticker on the LPT printer port. Write down the serial number, you'll need this when you make the call.
Mike
Jul 27, 2010 | ASUS P7P55D PRO Motherboard
Plugged computer back in after move and won't start. green light in mb on.
Actually, there is nothing you can do with the hard drive. If its shorting out the power supply when its pugged in then it is defective. However, most hard drives carry a 3 year warranty from the manufacture. If the drive is younger then 3 years old, I would call the manufacture and get it repaired or replace. Hope this helps . . .
May 16, 2009 | Antec EarthWatts EA380 380-Watt Power...
Asus K8V SE Deluxe - will not turn on
it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Dec 05, 2008 | ASUS K8V-MX Motherboard
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-SLI deluxe
for start
lets remove everything non essential to start up the pc.
Try with only one memory.
recheck psu connectors.
Jun 09, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
pls try change the power cable if it works then check your power pack if the FAN doesn't roll that means you have to change the power pack thanks. abass_october@yahoo.com
May 24, 2008 | Computers & Internet
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
Computers & Internet Logo
199 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
