Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Tv gone green/blue and sometimes red in top right corner
It is a blue green in the corner rest of the screen fine. was ok hour ago but now it got this triangle of miss colour.
Is my tv on its way out or is it something i have done.
I have just installed wireless router and this is at the side of the tv (opp side to colouration) and I had to move the tv to connect the wires etc.
    President:
  • 1,284 Answers
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Posted on Sep 10, 2009
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Colour wierd in corners of screen
do you have any speakers or magnets on top or near the tv.......if so move them away from the tv...thanks
Jan 04, 2010 | JVC AV-20F476 20" TV
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Red deflection is way off, picture scrunched into top right corner
call 800-648-6657 order part number CZ01341. This is the convergence output ic. You will need to replace the red convergence output ic IK04.
Dec 27, 2007 | Hitachi 60SDX88B 60" Rear Projection...
Screen is filled with a circular Red/Green/Blue pattern
The problem will be with the de-gausing circuit, this de-magnetises the tube when the set is switched on from cold, this is a fault you will need to get an engineer to look at ie, not a D.I.Y repair.
Mar 05, 2007 | Samsung TXR2675WH TV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
335 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
