Question about Yamaha RX-V2090 Receiver
Turns on then shuts down
My 2090 will power up for a sec., then shuts down. I took the cover off and checked the fuses, 3 that I can find and they are all good. The small board that the switched and non switched plugs are on has a small transformer that looks like it got hot enough to boil the varnish a bit. Could this be my problem?
  • 1 more comment
  • Saintinport Dec 10, 2007
    Thanks, I removed the speaker wires, and it still kicks off. On that small board I mentioned previously that small transformer looks like it mated with a relay and that is were the click is when it shuts down. Is this receiver worth digging into more? Its nice and I payed $1500. ten or so years ago.
  • mjtrager Dec 18, 2008
    I have the same problem with it turning on and shutting off. I do not have a short in the speaker either. nothing on the power inlet bd. is wrong. Where can I get the schematics or do you have any other suggestions?
  • murthy1502 May 11, 2010
    kindly help i have sam problem
    Problem Solver:
  • 6 Answers
It sounds like the amplifier protection circuit is kicking in. This usually happens due to a fault in one or both channels. Check that your speaker wires are not shorting out - try removing them and switching on.
Posted on Dec 10, 2007
Samsung TV no sound no picture backlight on and off
Check voltage at the power board. After 120 volts enter the TV, there is fuse then a small high voltage transformer, then a 100 uf rated at 450 volts capacitor. There should be 390 volts DC at the capacitor. Without this 390 volts the TV will shut down.
Dec 28, 2017 | Samsung Televison & Video
Samsung 5203 won't stay on
If power LED at its front panel is ON, the fault is with its main board. If it is OFF; the fault is with its main power regulator board, and related connection sockets. Check all the connection sockets, for any loose connections. Re-insert all of it once, and check. Contact any service technician. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Televison & Video
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
My lcd 1080 proscan turns off after 30 secs
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_2_2012_6_15_28_pm.jpg
Apr 02, 2012 | Televison & Video
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
GMP050-3 heater, gas turns on and lights for 5-7 seconds and just as thr igniter goes dim the gas shuts off. after 3 cycles the erd LED flashes on/off at a 1.5 seconds on and 1.5 sec off Gary
After the gas turns on, it is the flame sensor's job to see that ignition took place and send 24v to the gas valve. If it does not do this, the gas valve shuts down as a safety precaution. After 3 tries, the furnace will go into "lockout" and will not let it attempt to start again. The lockout can be resolved by turning off the power to the furnace for a couple minutes and then turning it back on. Sounds like the real problem is a faulty flame sensor not sending 24v to the gas valve. Sometimes they can be cleaned with a piece of sandcloth. This will cure failure to recognize the flame due to carbon build up on the sensor. Otherwise, the sensor will need to be replaced. Hope this helps!
Dec 16, 2008 | Goodman Heating & Cooling
Refilled, full ink cartridges, but...
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Aug 17, 2008 | Canon MX300 Office All-In-One Printer
Sharp Lcd Projector XV-H30U
check to see if you got the covers for the filters in the back and the side? if you dont have the cover for either of these it will not power up it only turns on for about 2 seconds and then it dies. it has a switch that must be pressed in when the covers are on. without the covers it only powers only slightly. you can jimmy rig it if you dont have the covers. try puting in something that is nonmetallic to depress the switch if your missing either th back or the side cover.
Feb 20, 2008 | Sharp (RLMPF0014CEZZ) Projector Lamp for...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Yamaha RX-V2090 Receiver Logo
266 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
