Question about HP OfficeJet 7310 All-In-One InkJet Printer
Plugged it in and installed software, but it says "Error 0x886a789e' and then a bunch of ?????? and stuff on the bottom of the screen. The auto answer, exclamation point, and on lights are all flashing as well.
  • 1 more comment
  • ilanakeilson Sep 10, 2009
    How long am I supposed to hold down ok and cancel? So far, none of this has helped.
    HP Officejet 7310 all in one:
    plugged it in and installed software, but it says "Error 0x886a789e' and then a bunch of ?????? and stuff on the bottom of the screen. The auto answer, exclamation point, and on lights are all flashing as well. Tried unpluggin and plugging in again several times, as well as # and 6 held while plugging in and ok and cancel held while plugging in. Nothing has helped so far.
  • ilanakeilson Sep 11, 2009
    did what you said but it didn't help. now wht?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow the below mentioned procedure as given--
A. Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 1-3 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
B. Perform a partial-full reset on the unit.
Press and hold # and 3 on the keypad and then plug the power cable of the All-in-One.
If the issue still persists
C. Peform NVM RAM reset on the unit :
Press and hold OK and Cancel while plugging in the power cord.
Please follow the above order as given. And before doing this unplug your Printer for 20 minutes.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 10, 2009
  • Rylee Smith
    Rylee Smith Sep 11, 2009
    If you have already performed all the steps that I gave you and still it wont work then you need to get your printer serviced.
    Thanks
    Rylee
  • HP Master
  • 4,806 Answers
This is an error related to HP printers.
1. Follow the steps below to power cycle your printer:
1. Verify that the unit is switched on. Unplug the printer from power and disconnect the connection port.
2. Wait 30 seconds.
5. On the third time after plugging the unit into power, reconnect the connection port from the printer to your computer.
2. Perform a partial-full reset on the unit.
Press and hold # and 3 or # and 6 on the keypad and then plug the power cable of the printer.
3. Peform NVM RAM reset on the unit :
This should resolve the issue. If still persists, please contact HP Technical support for further assistance
Hope this helps.
I turn my lenovoG560on it goes to start up repair then to blue screen then shuts down what can i do
First try this, Remove ALL media, DVD, CD, USB, etc., unplug, remove battery, plug in, reboot, use the F keys to restore/recovery software. If that fails, open the machine, reseat memory mods, reseat the HDD, replace the CMOS battery. You may have to remove HDD and test amd the memory and test. OR try a repair disk for your OS. Have you done any Hardware or software upgrades/changes?
Dec 25, 2012 | Computers & Internet
I am unable to download photos because when i try, i get an error message that says the application failed to run then when i click on details i get the java console window that lists a whole bunch of...
Please make sure you are using an unedited version of the image. Editing the photo using third party software may cause it to upload incorrectly or fail to upload entirely.
Please also make sure that the length or width of the photo you are uploading is not over three times longer than the other dimension.
Please note that we only support the uploading of .jpg, .gif, .bmp, and .png files.
The maximum file size is 15 MB.
Please make sure that you have the latest version of your browser installed and have also updated to the latest version of Java. If you continue to experience problems, please report this issue here. http://www.facebook.com/help/?faq=13265
Dec 31, 2009 | Computers & Internet
I have the same problem error message 0x886a789e
The surge has blown up the chipset that produces the signals required for faxes.
If you have a surge protector fitted then the maker should repair or replace the printer under their terms of warranty.
If they sell you protection then they have to offer it
Jun 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
F02 error on my kenmore elite H3
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 01, 2009 | Washing Machines
Getting an F 02 error code with my Kenmore Elite HE 3T
Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Error message
its the problem of internal white colour cable.
there are two white cables one the front pannel cable and other the scanner cable.any of the two cable could be faulty very rare chance of both faulty but may me faulty.
thanks
Aug 22, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Software application for my Kodak C743 has Parsing Error
You can solve this by renewing the software of you camera.
Please try to uninstall the sofware of your camera and then restart the system.
After restarting , install back the software, donot connect the camera while installing the software.
any problem arising this solution, notify me quick.
if this not solve the problem, maybe you should scan you system with antivirus: see the link for more info:
http://www.precisesecurity.com/antivirus/online-scan.htm
Please notify b4 you rate, thanks, Melnavz.
Feb 03, 2008 | Kodak EasyShare C643 Digital Camera
HP OfficeJet 7310 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
