Samsung Rear Projection TV Model No SP-43T5hp
Hi i purchased this TV , when you turn it on it has red ghosting . I have tried to adjust the convergence (it has a function - perfect focus) but nothing improve , do you have any suggestions,
My email is mfalla3@bigpond.com
i live in country queensland australia
thanks
  • dayman80 Dec 21, 2007
    I have a 3D shadowing on one side in the corner of the screen. I have tried the magic focus and tried focusing the projectsion lenses and it just made it worse. How do i adjust the convergence on the TV. The model no. is 53FDX20B.
  • mfalla Dec 23, 2007
    changed the convergence ic's but picture still the same
    Genius:
  • 1,694 Answers
How are you going?
Your repair solution is to replace STK392-040 convergence
IC's.........I use Panasonic brand for reliability or use Samsung
but no generics....they don't wear long........T.
Posted on Dec 10, 2007
  • 1 more comment
  • Vista Electronics Dec 10, 2007
    PS I will double-check part # for you........wait a few hours....
    Your Model not available in USA.... double check STK # on your
    part...............T.
  • Vista Electronics Dec 24, 2007
    mfalla,
    Under heatsink STK's mounted to, find small, brown pico fuses...
    check......in fact, check all fuse devices in convergence and power circuits...if you have service literature....check B+ supply
    to verify............................T.
I have a Samsung Model PCN5425R Rear Projection TV. When I try to set the convergence, the red will not move whatever I do, but the blue works fine.
If it is rear projection set it uses either two of the STK-392-020 OR STK-392-040 CHIPS FOR CONVERGENCE OUTPUT.
BOTH WILL HAVE TO BE REPLACED; NOTE THAT THESE SETS ALSO HAVE "PICO" FUSES ON THE BOARD FOR EACH CHIP--no movement means one of the fuses is blown because the chip shorted.
This can be a do it yourself repair if you are handy; total parts cost if the parts purchased on Ebay is under 30 dollars.
Let me know if I can assist you and if you have any questions reply to the posting here.
REGARDS, SD TECH
Aug 10, 2010 | Samsung PCN5425R 54" Rear Projection...
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Samsang Tv turns off and on all will.........do we have ghost?
Symptom shows that Lamp is weak and requires replacement.
How old is this TV and have you replaced its Lamp yet?
Apr 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Ghost like shadows
It seems your TV Samsung HCM4215W has problem in convergence board and need to be replaced.
You can get that board from Parts Store on $76
If you have bit electronics knowledge and know how about tv repair, you can replace it by yourself or get help of local tv tech person.
Oct 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red arched ghost
Thats not a valid Hitachi model number the sp4400 are audio speakers, but hitachi doesnt have model numbers for tV with sp can you please respond to this post with your model number and I will help you. SP43H is more like a Samsung model number.
Jul 15, 2008 | Hitachi 57F500 57" Rear Projection...
Convergence adjustments
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
http://servicemanuals.vstore.ca/
May 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
SAMSUNG TANTUS
Start with SAMSUNG.com---I had trouble with the model # you gave----?? Can your circuitry be repaired??If no,why???
Oct 08, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
370 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
