Question about HP LaserJet M1005 Printer
I am not able to use the scanning facility of hp laserjet m1005 on a macbook pro laptop computer
  • hcl2psiva Sep 15, 2009
    i am not able to use the scanning facility of hp laserjet m1005 on imac. how to start the HP scan application?
You can do it using Image Capture. First uninstall HP software, then with the printer turned on open Image Capture. Under Divices click Browse Divices then select Enable Twain (for your m1005).
Posted on Sep 07, 2010
How do I connect to an HP LaserJet 1020?
As the Laserjet 1020 not officially supported by the OS, you will need to download and install the HP Printer Drivers 2.11 package which include the Laserjet 1022 drivers, those should allow you printing using your device.
Install the package by following the Download below:
http://support.apple.com/kb/DL907
After completing the installation go to System Preferences ' Print & Scan and click the Plus sign,
Select the listed printer and click the Print Using drop-down.
Click Select Printer Software and then select the Laserjet 1022 which should be available now.
Complete adding the printer and try printing now.
GuruAid.com
Jun 27, 2015 | Apple MacBook Pro Laptop Computer with...
Tip
HP M1005 "Scan To" has disappeard in windows 7 - SOLVED
When I migrated to Windows 7 and installed the printer driver, the Scan To function disappeared.<br /> <br /> I then found a firmware upgrade located at<br /> <a href="http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1839458&prodNameId=1839459&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-43456-3">http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1839458&prodNameId=1839459&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-43456-3</a><br /> <br /> Download M1005_FW_Update-20070302.exe (2.4 MB) and run the upgrade.<br /> <br /> Then you press Windows Start, select Devices & Printers.<br /> Then when the printers are shown, right click on the HP LaserJet M1005 and you will find the new scan options appear.
on Mar 20, 2011 | HP LaserJet M1005 All-In-One Printer
Hp laserjet m1005 scaner error 20
Scan head drive mechanism faulty., Follow the snaps chk for breakages.,
Replace new part if its available, If not alter the part as shown in snaps..( ex:which I did early)
Feb 26, 2015 | HP LaserJet M1005 Printer
Why hp laserjet m1005 printer are scanner error 6?
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
Mar 29, 2012 | HP LaserJet M1005 Printer
My HP LaserJet M1005 Printer show Scanner error 12 and not work any copy print scan please choose a solvation
Remove: Operation panel, flat bed glass & scan head. Observe scan head mechanism drive gear placing pinion, if its broken replace the driver gear mechanism, if it is not available, make a metal pinion & fix there, but if you fails in first attempt, no second chance. Bee careful..best of luck...
Sep 26, 2011 | HP LaserJet M1005 Printer
How to scan on macbook air
Go to the applications folder in your mac. Then select "Image Capture" from there take the images you wish to scan and lay them on the scanner. Make sure its turned on and then press scan on the image capture screen.
Jan 04, 2011 | HP LaserJet M1005 Printer
I have hpm1005-mfp printer and want to install the same in my laptop having windows -7-64 bit OS.I have downloaded the same from hp driver site.Printer is working but i am not able to use scanner in the...
Maybe the software that was installed is not the correct one for the all in one .So check the HP site once again and see if there is a new link to get your software or post a query to them .
Sep 28, 2010 | HP LaserJet M1005 All-In-One Printer
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
HP LaserJet M1005 Printer Logo
635 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
