Question about Kenmore Slider/Casement Air Conditioner
My kenmore 12k BTU window unit will not turn on and behaves the same way as if unplugged... no sign of ''life.''
    Novelist:
  • 116 Answers
Hi, check house panel circuit breakers or fuses, check receptacle/outlet. if you got plug/receptacle, check for reset button, press reset. if there's power at receptacle, could be faulty circuit board. good luck
Posted on Sep 10, 2009
Were dose the green wire go to my senville 18000 heat pump indoor unit
The green thermostat wire goes to the G on the terminal strip. If it's not a thermostat wire it is a ground wire Should be grounded to the metal case for safety. It does not affect the operation.
Nov 14, 2014 | Senville 18000 BTU Dual Zone Ductless Air...
What is the tonnage of a Bryant model 563cno36-a
It is a 3 ton unit. 12,000 Btu per ton, the 36 denotes 36,000 Btu, hence 36k divided by 12k = 3 ton.
Aug 10, 2014 | Heating & Cooling
The ac quit, check all connections not an issue. took off front panel to see where reset fuse located. is there one? whirpool 12k btu 110v model ACM122XJ1 SERIAL# QK2343975 IF THERE IS RESET WHERE...
The easiest way to reset it is turn the unit OFF and unplug it for 10 minutes. Then, plug the unit back in and turn it ON. The 10 minute timeout will allow the electronics to reset and revert back to the original factory settings. If it is able to reset, it will do it then and you can set the controls as you like.
Thanks for choosing FixYa.
Jul 31, 2011 | Whirlpool Heating & Cooling
Just bought a kenmore 10000 btu window a/c unit - need to install
You CAN put it on the 3rd floor as long as you make sure it's completely secure. One thing I do recommend is building (or buying) a window unit shelf that sits outside the window and the air conditioner sits on it for extra support. The shelf is secured by the window frame.
There are many "how-to" guides to building a window unit shelf all over the internet.
I hope this helps.
Aug 17, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Can you use honeywell 12k btu air con in a room with no windows
you can, however the heat from the condenser will recirculate back into the evaporator, you need a place to discharge the hot air, and also the drainage from the condensate. I have cut holes in walls to the outside of the room in many applications with no windows, and they work fine. Just a matter of if you have an outside wall, and how much troble it is to cut the hole, frame the inside of the hole out, get power to the unit and secure the unit in the hole. Hope this helps...
Aug 15, 2009 | Air Purifiers
Maytag 18000 btu,my machine wouldn t turn on ,no sign of life
I't assuming that you have it hooked up to a dedicated 240volt 30 amp breaker.
Aug 01, 2009 | Maytag M6Y12F2A Air Conditioner
Kenmore 76081 cycling rapidly
check voltage when it shuts down possible motor overheating
Mar 09, 2017 | Kenmore 76081 Wall/Window Air Conditioner
Need information on the btu
Hey, Back -on line , & the answer to your question is ...go to webpage or type in whirlpool model window unit mod acq189! This equals to 17,800 btu 15 amps 220 volts 3 speed.
Jan 08, 2009 | Whirlpool Heating & Cooling
Heating & Cooling Logo
227 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
