Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Not enough hot water in one of my showers.
The people that lived here before had three kids and i was wondering if maybe there is something in the faucet that controls the hot water so that kids don't get burned. i don't know the brand of the faucet but it has one handle to turn the water on.
  •  Jerry
    Jerry May 11, 2010
    The maximum water temperature on most pressure balancing shower faucets can be adjusted, but the method for adjusting varies greatly depending on the make of the faucet. On Moen Posi-Temp valves, for example: - remove the handle - you should see a temperature limit stop which looks like a plastic ring with a pointer on it - pull the stop out, you will notice it has "gear-like" teeth on the back half - rotate the stop counterclockwise for hotter water, clockwise for cooler - reinsert the stop and reassemble the handle Try to locate the make and model of the shower valve for a more detailed and accurate solution.
  • 54 Answers
Turn the temperature down on your hot water tank to prevent scalding from all faucets.
Posted on Sep 13, 2009
Does not supply enough hot water
I bet you don't drain your tank every year. It accumulates something a little like sand . it may have been low enough to "suck" up some of this trash into the hot water lines and then to your valve and shower head. I would start with the head itself a good long soak in vinegar. If you have a spare shower head or hand shower head, I would let it sit for a week. While you have the "tempory" head installed, you can find out if the valve has been affected. Hopefully not. But if it is still slow flow, the trash may have accumulated in the valve. If that is what it apears and you have been considering a new valve now is the time. You may be able to flush it out with a direct connected garden hose. A "reverse flush would be the first try.
Mar 08, 2015 | Home
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
I have a Grohe shower system that has the temperature control it was working fine and now the water only comes out luke warm. the handle goes from 65 degrees to 110 degrees. I live in a older highrise...
WEll, the question is do your sinks have water that is hot enough? If no, perhaps your water heater is set too low. If yes, many shower controls have hot limiter and if you pull the handle, often there is a spline assembly that stops the travel from going hot, adjust to allow more.
Dec 13, 2010 | Grohe Home
I have to turn on lavatory faucet at the same time I'm running the shower so when I taking a shower the water doesnt go from hot to cold. It seams that maybe the hot water demad that the shower requires is...
This is not an uncommon problem with 'flash heaters' of this type; for safety, they all require a certain minimum of flow before the gas supply is turned on. Some brands/models have a factory-set adjustment for the minimum flow rate.
You might locate the mfr.'s website, contact them and describe your problem. This can also be caused by the modern flow-limited shower heads not allowing enough water to flow to keep the heater turned on.
If you have a retired shower head, you might try replacing the one currently used to see if it allows enough flow to allow proper operation. Either way, it is a waste of water.
Aug 03, 2010 | Kitchen Ranges
I just bought a repo house which has a grundfos circulation pump u p 15 installed at the water heater. House built 2005 4260 sq. Feet. House has 4 showers only one of them gets hot water. All sinks get hot...
that pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
May 20, 2010 | Home
Water becomes ice cold in the middle of a shower
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
WATER DELIVERED FROM SHOWER HEAD NOT HOT ENOUGH
I think some shower valves have a safety setting to prevent burning. maybe you could adjust that to be hotter.
Jun 23, 2009 | Home
Water heater has hot water in it but cold water is still flowing
Nothing wrong with waterheater. Did you perhaps reverse hot/supply lines on new shut off valves?? try reversing lines. Maybe
Please rate. Thanks jj505
Mar 28, 2009 | Whirlpool Water Heaters
Bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Feb 27, 2009 | Plumbing
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
202 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
