Question about Karcher G3025OH Pressure Washer
I have a Karcher 3000 model G3060 OH WITH hONDA G190
I have a Karcher 3000 model G3060 OH WITH hONDA 190. The engine starts&runs with lots of white smoke, runs a short time and dies out.The unit has hardly been used. Any ideas? Thanks, Bob
    Novelist:
  • 97 Answers
Did you loan it to someone? Perhaps someone put a fuel/oil mixture in it thinking it is a 2-cycle engine. That could cause white smoke. The other thing that causes white smoke is an engine carburetor not getting the fuel/air ratio right for some reason. White smoke means too much air -- too little gas. Your fuel filter could be stopped up or your gas could be contaminated with water or diesel -- or 2-cycle engine oil.
Posted on Feb 21, 2012
  • 174 Answers
It may be due to some water getting into the engine. I would change the gas and change the oil.
Posted on Sep 17, 2009
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Honda GX390 engine on Citation pressure washer: less than 50 hrs on pressure washer worked fine last year and was winterized all start settings correct; had to use starter fluid to start this year and...
Did winterising the engine include pouring lots of oil into the intake of the running engine until it choked and died? That is the classic method of winterising...
Heavy blue smoke is burning oil.
I expect the spark plug fouled in those few seconds. After winterising the spark plug usually needs cleaning several times before there is a reliable start and continued running.
Sep 28, 2017 | Motorcycles
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
White smoke. when it won't start, raw gas comes out of the exhaust GS190 honda Karcher 3000 PSI
Sounds like it's flooded. Close the throttle and open the choke if equipped. Pull it through a few times and then open the throttle a bit.
May 24, 2010 | Northstar Pressure Washer 3000 PSI
Engine will not remain running
sounds like the carb needs to be rebuilt and adjusted..good luck
Apr 03, 2010 | Karcher 2500 PSI Pressure Washer
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
Jul 05, 2009 | Karcher 2500 PSI Pressure Washer
Karcher G3025OH Pressure Washer Logo
762 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
