Question about Microsoft Xbox 360 Console
Even though i know my routers ip adress when i go to type it in it says internet explorer cannot find page as in it doesn't even exist now i have a sonic wall router that i need to buy a netgear thing that lets me play xbox but i cant join parties and on halo it says nat type not open i am really confused as to how im gonna acess the area when i change the settings?
    Sergeant:
  • 161 Answers
Well, first let me give you some computer info.
Even if you know your ip address and try it on IE, you are just pinging yourself (sending info to it and it will reply back, those info are just tests). What you need to do is go to your netgear address " http://192.168.0.1/ " Username: superuser or admin (if one don't work try the other) password: password (default). When you get in, that is where you can change your SSID (name for internet) and password/key.
Try this first.
I don't have a xobx for my reasons of hating halo, but my thought is on the main menu (if xbox does have that) there should be a network setting. Try resetting your internet.
Posted on Sep 10, 2009
Hi i had a wireless internet connection on my advent laptop till about 2 weeks ago and it doesn,t work anymore i have a internet conection as i,m using a different one and work perfect but this one...
Hi Friend, In this case as you have told me that you have other laptop which is working fine wirelesly. I would like you to check the IP address of the system in which you are facing the issues.
To check the IP address: 1) If system has XP Click on "Start" and then "Run". Type "cmd" in Run and hit enter A black screen will pop up, in that type "ipconfig", where the cursor will be blinking Check the IP adress under " Ethernet adapter local area connection" & " Wireless adapter"
2) If it is Vista/Win 7 Click on Start again and in Search field type cmd and hit enter Same black screen will pop up and repeat the same above steps in the black window and check the IP adress
Dec 07, 2010 | Computers & Internet
I need to know where to type in the ip address to configure my airplus extreme g router by dlink to get to the part where I put in the userer name Admin?
Open an Internet Explorer and at the adress bar (where you can see the internet url) type the ip address of the router without http://www before it, just the numbers separated by the dot. When you finish typing hit enter. Now there must be a window to type admin and password.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 03, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
What is my ssid
simple type cmd into the run command and then cd\
now type ipconfig
this will show you the ip adress of your default gateway
which is your router
write this down, now go to internet explorer and type it in there and it should open the home page of the router after this you need to look for security on that page and when you open that your ssid --wep/wpa will be there
Apr 11, 2010 | Arris SURFboard SB5120 Modem
Do you have internet explore ip address. it starts 192"?
what do you mean by internet explore ip?? just your computers IP?? or your routers IP??
normally the IP would be 192.168.0.XX submask is 255.255.2550
but if you just need to know your ip for now just go to START>RUN and type CMD that will open command prompt ( quick way is windows sign on keyboard + R ) to open RUN
once in CMD you type ipconfig then you'll see your IP adress, subnet mask and default gateway. hope this helps
Mar 05, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Unable to configure router. I am using Netgear router, WGR614
first enter to your network connections in control panel, double click local area network, properties, internet protocol(TCP/IP), and tick Obtain an IP adress....Obtain DNS server..... and after that ok...ok..ok.
Now open an internet explorer window and type in the adress bar 192.168.1.1 and press enter . if you are asked for username or password try writing admin on both. good luck!
Oct 27, 2009 | NetGear WGR614 Wireless Router
Connectivity
I think you mean that you configured your router at 198.168.254.254
in that case i would go to your network properties of windows.
set a fixed ip of 198.168.254.x (x= anything between 1 and 253)
set your gateway fixed at 198.168.254.254.
then open the explorer and type the adress of your router. Now you should be able to change the ip of your router and if needed enable DHCP.
if you enable dhcp go to your computer and set it do dynamic adress or get adress from dhcp.
or
set your ip settings of your computer as of it was before.
good luck.
Jan 20, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Connecting problems
First of alll on your comp...
click start>run>type in run box as cmd>it will open up a command prompt screen....
in that screen type in lowercase as ipconfig and press enter
it will give you a message like
ipaddress as 192.168.0.2
default gateway....192.168.0.1
if you get this message...then open internet explorer....
type in addressbar as 192.168.0.1
and try opening the page if page doesn't open up then...
1... unplug all the cables from your router...turn off your comp..
now connect just the power light in your router...and at the back of your router you'll get a rteset hole...in there is a reset pin you need press that pin woth a ball point pen for 15 seconds after that..connect the cables one that connects your router and phone socket and connect the ethernet cable as well it will connect your router and comp...
now open up internet explorer page again and try the same 192 address if you still don't get the page...
then if you're using windows xp.....
click start>run>type cmd>in the command prompt screen type in this command"netsh winsock reset catalog" without quotes and press enter...and after that restart your computer...
then again try opening the router page...
the page will open up......do this stuff and let me know about this i will send the screenshots for config the router....
thnks
Feb 20, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Microsoft Xbox 360 Console Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
